[GRASS-user] minimun (summed) cost under a polygon
I'm trying to find the location of a polygon over a cost-surface layer (raster) that represents the minimum possible cost when you add the pixels (cost) under it. The cost-surface has an irregular shape and the size of the polygon (in this case a square) is about 1/1000 of the size the cost layer. My approach (with a bash script) is to find iteratively a random location for the polygon, rotate it at fixed steps around it center (v.transform), calculate the sum of the cost under it at each rotation (v.rast.stats), and keep the location that produces the minimum sum of the cost. I could repeat the process, for example 1.000.000 times, and keep the location that produces the absolute minimum. I guess that the procedure should provide the right answer (a location), but, is there any other way to do that in a more efficient/elegant way? I'm also worry to be trapped around a local minima.
Saludos, EKS
Eduardo Klein
Lab Sensores Remotos y
Centro de Biodiversidad Marina
Universidad Simón Bolívar
Caracas, Venezuela
ph (58) (212) 906-3111 ext 6700
fax (58) (212( 906-3111 ext 6701
