Dear list,
I imported points from ascii table into GRASS 6.3 ORC5. Now I would like to assign values to these points. So doing the v.db.connect command GRASS tells me that there is no table for this layer.
Besides, using the v.db.addtable command to add an attribute table to the layer the message appears that there is already a table linked to the layer.
What to do now?
Regards
Chris
_________________________________________________________________
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
On Thu, Apr 24, 2008 at 5:03 PM, christian Brandt
<chrisbrandt74@hotmail.com> wrote:
Dear list,
Did you use the "column" parameter?
What does
v.info -c yourmap
say?
What to do now?
Regards
Dear Markus,
the following error message occurs:
DBMI-DBF driver error:
Table 'messstationen' doesn't exist
ERROR: Cannot open table
And that's the statement I used:
v.in.ascii -n 'input=/ output= format=point fs=| skip=0 'columns=x double precision, y double precision' x=1 y=2 z=0 cat=1
Did I set the right numbers for the columns?
Regards
Chris
Date: Thu, 24 Apr 2008 17:14:24 +0200
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] missing dbf table for point theme
wrote:
Dear list,
What does
v.info -c yourmap
say?
What to do now?
Regards
grass-user mailing list
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
