Dear list,
a newbie question follows:
I have managed to install grass64 using latest osgeo4w installer and can now (after a few modifications) run shell scripts in a Msys window. However, I noticed something weird: the fontcap file was referring to a directory which did not exist i.e. to /c/OSGEO4W/apps/grass/grass-6.4.0svn/fonts. I created the dir and ran g.mkfontcap with extradirs=c:/winnnt/fonts and it went through all right. But still, if I’m not mistaken, it seems that I can use only the default font. At least for labels.
Any idea how to fix this? can I just download the fronts from somewhere, install them to the fonts dir, and run the g.mkfontcap again?
ilumas
p.s.
uname -a in msys gives
MINGW32_NT-5.1 1.0.11(0.46/3/2) 2007-01-12 12:05 i686 Msys
Grass: GRASS 6.4.0svn
p.p.s
Needed osgeo4w installation tricks to start the grass64 and to run gdal and ogr tools from an msys window:
remove (skip) libjpeg-ipp package
remove zoneinfo package (last one)
open Msys shell
find /C/OSGeo4W/ -name 'Init.sh‘
change the value of GISBASE in /c/OSGeo4W/bin/grass64 to point to /c/OSGEO4W/apps/grass/grass-6.4.0svn
(mkdir c:/OSGEO4W/apps/grass/grass-6.4.0svn/fonts)
(g.mkfontcap -o extradirs=/C/winnt/fonts/)
for GDAL
if you see complains about missing DLLs, just rename/move corresponding libs located in
C:\OSGeo4W\bin\gdalplugins\ directory. Or install the required libs.
for OGR
The $GISBASE/fonts directory should exist (wherever $GISBASE happens
to be), and should contain files named fonts.table, hersh.oc1 through
.oc4, and various .hmp files.
The files can be found in lib/fonts/fonts in the source tree:
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/fonts/fonts
[The .or1 through .or4 files aren't used by GRASS.]
If those files aren't included in the installer, or if the fontcap
file refers to the wrong directory, submit a bug report.
I created
through all right. But still, if I'm not mistaken, it seems that I can use
Note that d.font doesn't work with direct rendering, which is the only
rendering mechanism available in Windows. From the command line, you
can set the GRASS_FONT and GRASS_ENCODING environment variables to
achieve the same result.
"d.font -l" should work to list the fonts, but setting a font won't
work (without a separate driver process, the setting is forgotten as
soon as d.font terminates). Commands which accept an explicit font=
option (e.g. d.vect) are unaffected.
