Under the section DESCRIPTION of the r.in.arc manual:
r.in.arc allows a user to create a (binary) GRASS raster map layer from
an ESRI ARC/INFO ascii GRID file with (optional) title.
The ARC/INFO ascii GRID file header has 6 lines:
ncols:
nrows:
xllcorner:
yllcorner:
cellsize:
# What should be the 6th line here?
or alternatively (not supported by r.in.arc, but by r.in.gdal):
ncols:
nrows:
xllcenter:
yllcenter:
cellsize:
Thank you,
Nikos
6th line is
nodata_value
and it's optional
http://docs.codehaus.org/display/GEOTOOLS/ArcInfo+ASCII+Grid+format
Daniel
On Mon, Jun 9, 2008 at 7:36 PM, Nikos Alexandris
ncols:
nrows:
xllcorner:
yllcorner:
cellsize:
ncols:
nrows:
xllcenter:
yllcenter:
cellsize:
Thank you,
Nikos
grass-user mailing list
grass-user@lists.osgeo.org
