Dear Grass community,
I have a mapset containing landsat channels B1,B2,B3,B4,B5,B6,B7,B8,B9,B10,B11 which are basically the result of the landsat_import script.
I want to load the mapset and run the following commands in order to perform i.landsat.toar, which does not work and returns exit code 1.
Graphical model works fine but when I export the model as a python script and run the script it also does not work.
grass.run_command("g.mapsets", mapset="LC81760382013119LGN01")
grass.run_command("i.landsat.toar",
input_prefix = "B",
output_prefix = "test",
metfile = metfile,
sensor = "ot8",
method = "dos4")
How do I run i.landsat.toar on my mapset using python. My goal is to include the toar transformation into the landsat_import script.
Greetings
