[GRASS-user] modeller in v6.4.2
I’d like/need to put together a model or two in grass graphical modeller but don’t seem to have the loop button and the ‘define relation’ button doesn’t work. I’m running grass v6.4.2 on ubuntu 12.04.
Any ideas gladly welcomed!
Michael
On 04/12/12 10:56, Michael Spencer wrote:
I'd like/need to put together a model or two in grass graphical modeller
but don't seem to have the loop button
You should at least be able to create a loop through the Model menu.
and the 'define relation' button
doesn't work.
Maybe you could be more precise: How are you trying to make it work and what is the result ?
Moritz
2012/12/5 Moritz Lennert <mlennert@club.worldonline.be>:
doesn't work.
is the result ?
note that the graphical modeler is provided as experimental prototype.
Better is to try modeler in 6.4.3svn or in the best case in 7.0svn.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
doesn’t work.
I click on the button and nothing happens…
Will have a crack at scripting what I want to do in python but may come back to this. Martin - thanks also for your tip!
2012/12/5 Michael Spencer <michael_spencer@live.co.uk>:
I click on the button and nothing happens...
do you mean 'relation' button? The relations should be created
automatically when adding modules to the model.
Martin
2012/12/5 Michael Spencer michael_spencer@live.co.uk:
do you mean ‘relation’ button? The relations should be created
Yes it does seem to be doing that today… how odd.
