is it possible within GRASS to modify feature’s values (of the feature attribute table) interactively (e.g. like in ArcGIS, where I can select an object within the view which then can be modified/removed…)?
2008/3/26, christian Brandt <chrisbrandt74@hotmail.com>:
is it possible within GRASS to modify feature's values (of the feature
object within the view which then can be modified/removed...)?
you mean to modify attribute data of vector objects? If so, yes, you
can use v.digit or digitizer in wxPython GUI (experimental).
IMHO there should be a solution outside of the digitizer (i.e. without risking any alteration of the actual map), something along the lines of "d.what.vect -e".
Christian, if this is what you need, you will have to use it with the "old-style" x-monitors from the command line, i.e.:
d.mon x0
d.vect YourMap
d.what.vect -e YourMap
This is typically one element which would be GUI-only as I don't think it would make much sense to program an interactive command line version...
2008/3/26, Moritz Lennert <mlennert@club.worldonline.be>:
Moritz:
"d.what.vect -e".
d.mon x0
d.vect YourMap
So maybe something to think about for wxgrass.
hm, it wouldn't be so difficult to implement, sorry, back to the
reality;-) Basic implementation is here
Moritz:
"d.what.vect -e".
d.mon x0
d.vect YourMap
Also: probably the button's properties should be changed so that you can click on it again directly to change from one mode to the other. Currently you have to click on another button and then back on the query button to change mode.
strange, I used for testing also 'roads' from spearfish60, seems to work.
You don't need to change a tool, double-click on 'query' should show menu again.
just a guess: you were not in the PERMANENT mapset when you tried this
test? You can only edit maps in the current mapset (or at least that
should be the case) -- and the same is true for DBs.
If that is the problem here, I guess we need to add some more tests and
more appropriate error messages.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
yes, you can use v.digit or digitizer in wxPython GUI
(experimental).
Moritz:
d.mon x0 d.vect YourMap d.what.vect -e YourMap
hm, it wouldn't be so difficult to implement, sorry, back to the reality;-) Basic implementation is here
