[GRASS-user] module v.in.e00
I have a problem with this import command. Whenever I try to import an E00 file it shows that I have not installed. I checked it again by running the OSGEO4W installation patch and there I crossed checked that avce00 library is also installed, but this problem simply does not go away and it keeps recurring as folows.
v.in.e00 “file=C:/Documents and Settings/ishan/My Documents/Downloads/25192/hypoint.e00” type=point vect=hypoint
which: e00conv: unknown command
‘e00conv’ program not found, install it first
http://avce00.maptools.org
Finished with error
Help is needed!
Ambrish Dhaka
2010/8/6 ambrish dhaka <ambijat@hotmail.com>:
'e00conv' program not found, install it first
it seems to me that the message is quite informative - download &
install e00conv from http://avce00.maptools.org/.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
[please keep discussion in ML]
2010/8/7 ambrish dhaka <ambijat@hotmail.com>:
Linda,
people call me in different ways :wink:
If one installs from the OSGEO4W patch it shows in command line utilities
there, so there is no question of installation as separate module.
Thanks for candid observation but I need real help
Well, my reaction was not sarcastic, I just haven't read your mail
carefully. That's my fault.
The problem is that when you install avce00 in OSGeo4W stack,
e00conv.exe is not available. It's just missing, try to ask at osgeo4w
ML. It doesn't seems to be problem of GRASS.
Martin
