[GRASS-user] [more] issues with python scripts
just to add to the last email:
grray() isnot working.
this is what I get, with any raster:
a = garray.array()
a
array([[ 0., 0., 0., ..., 0., 0., 0.],
       [ 0., 0., 0., ..., 0., 0., 0.]])
a.read("elevation.dem")
Sorry, <f> is not a valid flag
Sorry, <bytes> is not a valid parameter
1
cheers
carlos
Prof. Carlos Henrique Grohmann - Geologist D.Sc.
Institute of Geosciences - Univ. of São Paulo, Brazil
http://www.igc.usp.br/pessoais/guano
http://lattes.cnpq.br/5846052449613692
Linux User #89721
________________
Can’t stop the signal.
>>> a = garray.array()
>>> a
This suggests that you're using 6.x.
The grass.array module won't work with 6.x, as it requires changes to
r.in.bin and r.out.bin which are only present in 7.0. It was
back-ported to 6.x by mistake, and should probably be removed.
2011/1/17 Glynn Clements <glynn@gclements.plus.com>:
right, done in r45066.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Mon, Jan 17, 2011 at 6:08 PM, Glynn Clements
But cannot we backport instead the r.in.bin and r.out.bin changes? To
keep array in GRASS 6?
