[GRASS-user] More on v.net.steiner
All,
I found a brute-force way to identify the unreachable categories; I set up a loop in d.path to connect all categories to all others, with the output pipelined to a text file along with cats.
OK; with the offending categories removed from the points, I then ran v.net.steiner again.
In Grass-6.3 on Mac OSX, it crashes after the cost initialisation step (Init costs from node ###) with a bus error. However, it works okay in Grass-6.4 on Linux.
Richard Chirgwin
On Wed, Sep 9, 2009 at 7:14 AM, Richard
Chirgwin<rchirgwin@ozemail.com.au> wrote:
All,
Wouldn't v.net do the job?
http://grass.osgeo.org/grass64/manuals/html64_user/v.net.html
-> Example
    "... create lines map connecting points to network (on layer 2)"
All,
-> Example
Markus,
I had already run v.net to create the connection from point to network. Where it fell down was for points that couldn't connect, because v.net.steiner reports the failure to connect using node number rather than category number (so for eg the cat might be 10 but the node 639). My nasty brute-force was to create a text file that clearly put node number and cat number together.
(The network was roads; the points that didn't connect were in the water, which is fair enough I suppose!)
Richard
MN:
RC:
how about v.net.iso then split away areas with infinite cost.
Hamish
MN:
RC:
Hamish
Thanks, I’ll give that a try.
Richard
