Hi!
A newbie doubt: I have to make a mosaic with 2 satellite images (CBERS). The border values are “0”. What is the procedure? (the images are already on grass).
Raphael Saldanha
BRAZIL
Hi!
Raphael Saldanha
BRAZIL
On Fri, 2008-08-08 at 08:57 -0300, Raphael Saldanha wrote:
Hi!
(CBERS). The border values are "0". What is the procedure? (the images
are already on grass).Raphael Saldanha
BRAZIL
Hi Raphael.
If your images are correctly georeferenced then you only need to use
r.patch or r.mapcalc.
Set the extent of the computational region with g.region first, for
example:
g.region rast=satimage1,satimage2 -pa
Then patch:
r.patch in=satimage1,satimage2 out=mosaic
Kind regards, Nikos.
On Fri, 2008-08-08 at 09:53 -0300, Raphael Saldanha wrote:
Hi Nikos!
Thanks for the advice!
So, I use this:
Set null values: > r.nul
Set region: > g.region
Create mosaic: > r.patchThanks!!!
On Fri, Aug 8, 2008 at 9:26 AM, Nikos Alexandris
> Hi!
images
(the images
> Raphael Saldanha
> BRAZIL
Hi Raphael.
to use
first, for
example:
Then patch:
[cc-ing to the list]
Raphael, it is not required to set any NULL values I think, except if
you need it for your own reasons to set NULL values.
Cheers, Nikos
