Hello,
I know that people work with entire GISDBASES on remote server, often via NFS, but does anyone have experience with mounting only one mapset from a remote server into a location on the local machine ?
Moritz
Hello,
Moritz
On Thu, Oct 30, 2014 at 10:23 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Hello,
Yes, we have. What is the specific question?
<mlennert@club.worldonline.be> wrote:Hello,
remote server into a location on the local machine ?Yes, we have. What is the specific question?
Any specific hints about possible difficulties ?
I am trying to figure out the best way to allow students to work on VHR-imagery in computer labs where their own sessions are limited in terms of disk space and where the file server is normally read-only for students.
Moritz
On Thu, Oct 30, 2014 at 11:03 AM, Moritz Lennert
As long as you have a stable network connection, no issues.
ok, so you may set it up like this:
(NFS)Server:
/storage/grassdata/<various locations>
--> export /storage/grassdata/ as read-only NFS share
Put all data into the PERMANENT mapset.
Student machine(s):
# as root, one time needed (add to /etc/fstab):
mkdir -p /storage/grassdata/
mount via NFS /storage/grassdata/ into /storage/grassdata/
# as user:
mkdir $USER/grassdata
mkdir $USER/grassdata/location1
ln -s /storage/grassdata//location1/PERMANENT $USER/grassdata/location1/
now start GRASS with $USER/grassdata/ and location1 and create a new
user mapset within it.
That will stay locally while PERMANENT comes from the NFS server in read-only.
students.
We had recently similar issue. We had read-only GRASS location.
Unfortunately the client OS was MS Windows, so the nice trick with mounting
and symbolic link is not applicable.
> students.We had recently similar issue. We had read-only GRASS location.
http://en.wikipedia.org/wiki/NTFS_reparse_point
http://en.wikipedia.org/wiki/NTFS_symbolic_link
On Fri, Oct 31, 2014 at 5:53 PM, Glynn Clements <glynn@gclements.plus.com>
> > students.
mounting
> and symbolic link is not applicable.http://en.wikipedia.org/wiki/NTFS_reparse_point
Thanks, my bad, now I have a challenge to explain to IT department what I
want
<mlennert@club.worldonline.be> wrote:On 30/10/14 10:52, Markus Neteler wrote:
FWIW, added also here:
http://grasswiki.osgeo.org/wiki/Location_and_Mapsets#Using_GRASS_GIS_locations_in_a_network
