Dear GRASS-users,
I want to obtain a movement cost layer (r.walk) which only regards pure walking cost (without a friction layer). I've generated a 32 bit geotiff DEM (not too big) and a constant value = 1 grid as friction surface (for being neutral). Unfortunately GRASS only gives me a symmetrical result as there would be no relief.
Is is not possible to perform a simple movement-cost analysis without any optional friction maps? Using a constant value grid (or lamda = 0) doesn't work unfortunately. I'm always getting symmetrical/euclidean results.
Thank you!
Regards
David
Hello,
i posted that question already some time ago but didn't get any
reply/idea...
Here again:
I am looking for the literature reference for Boyle's algorithm in v.generalize. What is the source this tool is based on. Does anyone know
the original literature?
Thank you
/Johannes
NEU: FreePhone - kostenlos mobil telefonieren!
Jetzt informieren: http://www.gmx.net/de/go/freephone
On Wed, Jun 8, 2011 at 2:30 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
Hello,
reply/idea...
Here again:
No answer usually means no. I had a look at the source code, but there
is no reference (neither in the manual). Maybe Daniel Bundala, the
author of the module, knows a reference for Boyle's algorithm. This
module was a Google Summer of Code project; maybe you find something
if you read through the corresponding threads.
Markus M
