[GRASS-user] Moving windows on raster categorical map
Dear Grass-experts
I have a categorical raster map with 5 classes.
Now I need to estimate some stats using different-sized windows
like 3x3, 5x5…25x25. The stats the I would like
to compute is to count the number of classes on
the windows, to estimate the percentage of an
class of interest (like class 4, for example),
and other stats that could be computed using
the pixels inside the windows.
As you can see, the size of windows will varying,
so as final solution I think to include the solution
on a “for XX in ()… done” looping.
Any help are welcome.
On Wednesday 05 November 2008, Milton Cezar Ribeiro wrote:
Dear Grass-experts
like 3x3, 5x5..25x25. The stats the I would like
on a "for XX in ()... done" looping.
r.resamp.stats
r.neighbors
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
r.neighbors, possibly in conjunction with r.mapcalc and/or r.reclass.
"r.neighbors method=diversity" will count the number of distinct
categories within the window.
"r.neighbors method=average" will calculate the mean of the values
within the window. If you generate a reclass map so that the category
of interest maps to one and the other categories map to zero, this
will calculate the proportion of cells which have the desired
category.
If you want something which can't be computed by r.neighbors in
conjunction with some pre- or post-processing steps, you can either
modify r.neighbors, or produce something equivalent using r.mapcalc.
There is no specific limit to the complexity of an r.mapcalc script,
although complex scripts can be quite slow. OTOH, r.neighbors also
gets slower in proportion to the number of cells in the neighbourhood
window.
