I'm a three-day-old grass user, so my question can result a bit silly,
but I searched anywhere on the web, without any answer.
I have a set of 1546 centroids which refers to as many areas of a vector
map. Some of these centroids points to more than one polygon, so my
attempt to set a column in a table with these centroids miserably
fails.
I try to make something like this:
v.db.addcol mymap col="x double precision,y double precision"
v.to.db mymap type=centroid option=coor col=centr_x,centr_y
When I run the v.to.db command, Grass return as many warnings as are the
areas with "doubled" centroids.
I read that I have to use the v.category command, but I really don't
know how to use it!
Any idea?
Thanks in advance,
Moreno Mancosu
