Hi grasslist,
I have a MIF/MID file with city names of europa. I have imported this one into GRASS and I’ve worked with the layer in sqlite. Then I have exported the layer to shp and then I notice that the german, polish and other special characters have disappeared.
I’m not sure, but probably in the source data (the MIF/MID file) the city names are encoded with the correspondent language code.
Have someone any idea, how can I resolve this problem?
Best regards
Manuel
On Fri, Jun 13, 2008 at 11:03 AM, Manuel Sangiao <masanlo1@gmail.com> wrote:
Hi grasslist,
into GRASS
I suppose you used v.in.ogr?
and I've worked with the layer in sqlite. Then I have exported
I suppose you used v.out.ogr?
I'm not sure, but probably in the source data (the MIF/MID file) the city
I think that this might be an OGR problem (found for example
http://www.nabble.com/Encoding-in-ogr2ogr-td10168817.html#a10168817
Could you try to convert it via ogr2ogr to see if the accented characters
survive? If yes, it's a GRASS problem, then we need to check that. If
not, please report to the GDAL mailing list then.
Markus Neteler pisze:
Hi grasslist,
into GRASS
Did you see characters in GRASS properly (i.e with national characters?
what was the encoding of Mapinfo files?. As I remeber Mapinfo files code chars in natiolnal standards (for example for polish it is often windows 1250)
mid is comma separated ascii file try tu check his encoding - if it is UTF-8 try to use postgreSQL instead SQLIte
grass-user mailing list
grass-user@lists.osgeo.org
Hi
It is
