[GRASS-user] multiple points for r.water.outlet
Hi GRASS folks!
Is there a way to use multiple points as input for r.water.outlet? I have a textfile with 49 pairs of coordinates (points). For each of these 49 points I want to calculate the corrosponding watershed.
I thought about a shellscript which reads every line of the textfile and uses them as input for r.water.outlet. But I wonder if there's a smarter way to do this.
Malte
Dear Grass Users
I'm using the grass native on windows (qgis 0.8 with grass) but I have an
error when I use r.watershead.
This is the error I have:
r.watershead elevation=dem_20 threshold=4000 drainage=drain
Warning category information for [drain] in [tagliamento150] is missing or
invalid.
Thanks
Pierluigi De Rosa
an error when I use r.watershead.
missing or invalid.
can you reproduce this with the spearfish dataset?
does it work with the Cygwin 6.2.1 install for windows?
Hamish
Hi Hamish
Yes, I have exactly tha same problem also with the spearfish dataset...
I don`t know if on Cygwin it works!
sorry
Pierluigi
missing or invalid.
Hamish
On Wed, 7 Mar 2007, Pierluigi De Rosa wrote:
Hi Hamish
It works for me on native Windows, current CVS (note I'm not using QGIS):
GRASS 6.3.cvs (spearfish):C:\Documents and Settings\Paul >r.watershed \
elev=elevation.dem thresh=4000 drainage=drain
SECTION 1a (of 5): Initiating Memory.
SECTION 1b (of 5): Determining Offmap Flow.
  100%
SECTION 2: A * Search.
  100%
SECTION 3: Accumulating Surface Flow.
  100%
SECTION 4: Watershed determination.
SECTION 5: Closing Maps.
Something worth looking at might be whether it is line-ending related. In my local copy of lib/gis/getl.c I have the body of G_getl() replaced by a call to G_getl2() {G_getl2() copes with Windows line endings when reading text files}. BUT I just changed it back and tried r.watershed again and it still works. But that could just be because my spearfish has Unix line endings on the raster cat files - it could still be a problem. Or I could be totally on the wrong track. There might be some other native Windows changes that have "accidentally" fixed it.
Paul
missing or invalid.
Hamish
grassuser mailing list
grassuser@grass.itc.it
missing or invalid.
dataset...
with what command line? and what are the region settings?
I'd like to try and reproduce it here.
ok, but be aware that Cygwin GRASS for MS Windows is the stable version,
and native MS Windows versions are still highly experimental.
Hamish
