[GRASS-user] Multiple regions: same bounds, different resolutions
   To have a region (based on a vector map) with different resolutions for
different models would this sequence of commands work?
g.region vect='vector_map' # default resolution is 1m
g.region save='res_1m'
g.region res=500
g.region save='res_500m'
   Then I would set the region as needed for a model by specifying
g.region name='res_1m'
or
g.region name='res_500m'
   Some models work on a small area where the 1m resolution is needed while
other models act on much larger areas and benefit from a larger resolution.
   If there's a more appropriate way to have multiple resolutions based on
teh same source I want to learn about those.
Rich
