I downloaded a National Elevation Dataset layer from the USGS. I haven't any idea of how to import it as a raster layer. Its got several types of files: .dir, .dat, .nit, .aux, .adf, as well as some esri metadata files (.dbf, .prj, .shp, shx). Can anyone tell me which file is the one I want to try to import as a raster file?
I believe that it is the aux file, but it could be the adf file I
don't remember. Normally they have w*************.adf or aux and I
think it is the last file in the list. I suspect you can find this on
the internet or the archives. I probably asked this same question
some months ago.
HTH
Stephen
On Fri, Apr 2, 2010 at 5:19 PM, Kurt Springs <ferret_bard@mac.com> wrote:
Hi Folks,
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
file?
I am using the Mac OS X Version. I downloaded the file NED_85826542\ned_85826542\w001001.adf. I tried changing the name to w001001.adf and got the same error.
Kurt
On Apr 3, 2010, at 3:13 AM, Markus Neteler wrote:
On Sat, Apr 3, 2010 at 2:47 AM, Kurt Springs <ferret_bard@mac.com> wrote:
I tried that and got:
r.in.gdal -e {input=/Users/kurtsprings/grassdata/NED_85826542/NED_85826542\ned_85826542\w001001.adf} output=dem
ERROR 4: `/Users/kurtsprings/grassdata/NED_85826542/NED_85826542\ned_85826542\w001001.adf' not recognised as a supported file format.
I see switched \ and /. Looks like windows...?
Which winGRASS version do you use (too old?)?
Also, I tried changing the name so that the file itself was just w001001.adf and got the same thing.
Kurt
On Apr 2, 2010, at 8:35 PM, Markus Neteler wrote:
On Sat, Apr 3, 2010 at 1:19 AM, Kurt Springs <ferret_bard@mac.com> wrote:
Hi Folks,
I have found that the NED zips do this on OSX. So instead I change the download options to a tarball. Simpler than try to reconstruct the folder structure.
Kurt
Kurt
Hi Folks,
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
I concur with William. Part of my workflow on the seamless server is to always go into the options and make any downloads tgz's. Otherwise, you get a mess that is a challenge to untangle.
This requires a few extra mouse clicks, but it makes a big difference in the end.
Good luck,
John
Kurt
Kurt
Hi Folks,
How do you set up the site to download tarball instead of .zip. I tried but it does not give me the option to download tarball.
Kurt
Kurt
Kurt
Hi Folks,
When you select an area, and you are at the Request Summary page, click Modify Data Request. There you can select the Archive Format for each dataset.
I don't know if there is a way to change this *before* selecting areas.
Kurt
Kurt
Kurt
Hi Folks,
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
Okay that worked. Thanks a lot William and John and all who offered suggestions.
BTW, I just wanted to let people know that I completed my requirements for the Ph.D. at University at Buffalo. So, thanks too to all who gave me advice during the struggle.
Kurt
Kurt
Kurt
Kurt
Hi Folks,
