[GRASS-user] Native WinGRASS 6.4 RC5 g.proj failure
maven apache wrote:
I think I came across the same problem of the g.proj
the commond "g.proj -c
georef=d:\swilAlphaTIFF.tif location=tset" works
well in grass6.3 get some warning in grass6.4 6.4 RC5
(Wed Jun 17 18:27:31
2009)
g.proj -c georef=d:\swilAlphaTIFF.tif location=tset
Trying to open with OGR...
Trying to open with GDAL...
...succeeded.
ERROR: 要得到当前地图集未设置的范围
请运行 "g.region"
ERROR: region for current mapset is not set
       run "g.region"
found it,
  https://trac.osgeo.org/grass/ticket/654
I traced this back to r37726 where wind_format.c's format_double() uses G_projection() which wants to check the projection type (and that hasn't been created yet). Not sure of the best solution yet.
Hamish
       run "g.region"
found it,
I suggest simply reverting r37726. Changing a function so that it
requires GRASS to have been initialised ($GISRC, WIND, etc) when it
didn't previously is a fundamental API change.
