[GRASS-user] nc_spm_08 - 'cat' double
some vector maps from nc_spm_08 uses double precision column as key
column. Then some modules fails...
v.info geology -c --q | grep cat
DOUBLE PRECISION|cat
v.extract in=geology where="cat > 10 and cat < 20" out=geology1 --o
ERROR: Column <cat> is not integer
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2009/10/18 Martin Landa <landa.martin@gmail.com>:
in GRASS 7 we can support as key column also non-integer columns, but
that's not question for GRASS 6.
Martin
On Sun, 2009-10-18 at 12:24 +0200, Martin Landa wrote:
Martin, I have downloaded the nc_spm_08 dataset around May (date of
directory is 2008-05-18).
GRASS 6.4.0svn (nc_spm_08):/geo/grassdb/nc_spm_08 > v.info -c geology | grep cat
Displaying column types/names for database connection of layer 1:
INTEGER|cat
I guess something has been changed (?) since then.
Nikos
Martin
2009/10/18 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
INTEGER|cat
no, it's seems to be bug in GRASS 7 - GRASS 6.* reports 'int'.
Martin
Nikos Alexandris:
> directory is 2008-05-18):
> INTEGER|cat
OK. Here the same with grass70 - confirmed.
Nikos
Martin Landa wrote:
See [1]. A wild guess: grass7 uses gdal and not the internal shapelib to open dbf files? At least in gdal-1.6.2, column <cat> would be interpreted as double because field length is >10. The <cat> column of geology is really integer, not double, because there are 0 decimal places.
Markus M
[1] http://trac.osgeo.org/gdal/ticket/809
2009/10/18 Markus Metz <markus.metz.giswork@googlemail.com>:
right, see http://trac.osgeo.org/grass/ticket/792
Martin
