Huub Munstege wrote:
Hello Nikos,
Hello Huub!
thx for the swift reply. I'll check out the options you mentioned but at
first sight I noticed that 'i.vi' tool is not available for me ( I'am on
6.4.3-rc, from the AUR package in Archlinux). I.vi is not a command in the
'standard' Grass trunk. Neither is it available as an add-on.
Right! Apologies from my side. I have a setup giving access to all grass
modules outside of a grass session [see link to GRASS-Wiki below] which, if
not properly handled, as described in the wiki ("strip paths"), it even allows
access to all grass70 modules from inside a grass64 session.
Some more explanation as you asked: previous Landsat 7 images we analyzed
with a simple raster calculation with the following formula:
float(Band-4 - Band-3) / (Band-4 + Band-3).
I guess using grass64 means sticking to the formula above for NDVI.
But as you already noticed the bands and ranges have changed under Landsat
8. Various combinations of bands (4,5 and 8) give a result that is at best
not so clear cut as the analysis done with L-7.
I didn't test any L8 so far, though I have downloaded some scenes. Strange,
in a way -- I would rather think that their improvements would improve S-N-R
and, thus, derive "better" vegetation indices... :-?
The "bluntly subtraction with 0.12" is based on on a quick scan of the
obtained result. Areas without vegetation in our project area should give
values in the range between -0.05 - 0.
as per L7 data I guess...
The result of the combination of the 5 and 4 bands in the above formula
gives values that are aprroximately 0.12 higher.
I see.
Therefore the blunt and in-elegant subtraction which is definitely wrong.
But it gives us for the time being a better deistinction between cultivated
irrigation schemes and their surroundings. Maybe I am simply too impatient
and too eager to work with the new fresh data from L-8.
Sorry for asking again: did you correct the data in some way or did you
simply feed the formula with DNs?
Undoubtedly soon, Grass and the other software will incorporate specific
modules that will be tailored to the L-8 sensors.
Cheers and keep up the good work,
Thank you for all of the details regarding your work.
Nikos
<http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29>
