I'm new to GRASS, even newer to WMS and am trying to import some nearmap
tiles. I have some partial success as shown below.
Could the solution be changing file extensions and running gdalwarp with
appropriate parameters?
If so I have no idea of the next step.
I've tried changing the file extension to .tiff but the file is
unreadable by GIMP
Thanks
Tony
GRASS 6.4.0RC5 (NorthernLP):~ > r.in.wms layers=Adelaide_Australia
mapserver=http://wms.nearmap.com output=nearmap01
Calculating tiles
Requesting 4 tiles.
Downloading tiles
Downloading data
2010-05-09 17:45:23 URL:http://wms.nearmap.com/ [89012/89012] ->
"/home/..../grassdata/wms_download/nearmap01__0.geotiff" [1]
All tiles downloaded successfully
ERROR 4: `/home/....../grassdata/wms_download/nearmap01__0.geotiff' not
recognised as a supported file format.
ERROR: r.in.gdalwarp: gdalwarp failure.
ERROR: r.in.gdalwarp failed
Hamish
2
some nearmap tiles. I have some partial success as shown below.
gdalwarp with appropriate parameters?
file is unreadable by GIMP
Calculating tiles
Requesting 4 tiles.
Downloading tiles
Downloading data
[1]
ERROR 4:
not
see https://trac.osgeo.org/grass/ticket/1025
an error occurred and the error detection logic failed so you don't
see the useful error message explaining what went wrong.
the downloaded "tiff" image probably contains some text file.
you'll have to remove it otherwise it will think the tile is already
downloaded.
as it generally works for me, I'd need to know the output of:
cd $GISBASE/wms_cache/
file -b really_a_xml.tif
in order to improve it.
what operating system + version do you use?
often the "-g" flag helps when working with older WMS servers.
good luck,
Hamish
