[GRASS-user] NED Shaded Relief, Grass 6.4
Hello Folks,
I am trying to create a shaded relief map based on a 30-meter NED file using r.shaded.relief. The results are very ‘blocky’ (or stair-stepped). Running a 5-cell average neighborhood across the DEM did not help. Can somebody tell me the correct procedures I should follow to create the relief map that is smooth?
I’ve put a screenshot of my initial shaded relief map up here to show you what I’m talking about…
http://www.rlogis.com/GMaps/test/grass64_shadrel.jpg
Thank You Much.
Tripp Lowe
Tripp,
On Sat, Apr 11, 2009 at 8:05 AM, Tripp Lowe <tripplowe@gmail.com> wrote:
Hello Folks,
r.shaded.relief. The results are very 'blocky' (or stair-stepped). Running
smooth?
I've put a screenshot of my initial shaded relief map up here to show you
what I'm talking about...
did you run
g.region rast=your_ned_map -p
before
r.shaded.relief
? I suspect that your current region is of lower resolution right now.
