I am looking for suggestions on a query of worldclim data (http://worldclim.org/).
I have used something similar to below for previous data extraction where I am looking for data associated with a particular site, or list of sites, where a single lon lat coordinate will return a single value. However, in this case, I need to pull an entire longitudinal band for a particular latitude.
For example instead of grabbing data from a single coordinates with "east_north = -92.50, 46.51”, I want to grab all the data in the longitudinal band at latitude 46.51.
If it were possible something like “east_north = *, 46.51”
Any suggestions on this point would be much appreciated. Thanks in advance - Kirk
if test “$GISBASE” = “”; then
echo “You must be in GRASS to run this program”
exit
fi
Use input text file for coords in the format: lon lat (easting northing) single
space between coords. Example: -98.42072 55.91481. Must use real coordinates, no blanks.
Script will create file for each $MAP in the list. g.mlist can also take the “pattern”
argument which takes regular expressions. For example: pattern=“*” returns all
maps in the database. If script fails check for hidden characters in text file, best to
use vi or emacs to eliminate them
for MAP in g.mlist type=rast pattern=“HIST_tmin*"
; do
r.what --verbose input=“$MAP” < ~/Desktop/ai/coords.txt > ~/Desktop/ai/“$MAP”.txt;
echo “$MAP”
done
