I am new to GRASS software.
I successfully added v.neighborhoodmatrix addon in GRASS 8.0 manually , but I couldn’t use it.
https://grass.osgeo.org/…/addons/v.neighborhoodmatrix.html
Please, is there someone who can help me with@.
Your help will be greatly appreciated , thank you.
Best Regards
Hi Mohajane,
Le 23 février 2022 16:44:21 GMT+01:00, Mohajane Meriame <mohajane.meriame13@gmail.com> a écrit :
I couldn't use it.
Could you explain what you mean by that ? What did you do and what exactly went wrong?
Moritz
Thank you very much for your support Moritz Lennert,
I successfully added v.neighborhoodmatrix addon in GRASS 8.0 manually , but the plugin is not appearing in the list of extensions in GRASS software.
Regards.
Meriame
Le mer. 23 févr. 2022 à 18:58, Moritz Lennert <mlennert@club.worldonline.be> a écrit :
Hi Mohajane,
I couldn’t use it.Could you explain what you mean by that ? What did you do and what exactly went wrong?
Moritz
I successfully added *v.neighborhoodmatrix *addon in GRASS 8.0 manually , but the plugin is not appearing in the list of extensions in GRASS software.
Regards.
Meriame
Seems to be working here:
micha@RMS:GIS$ g.version
GRASS 8.1.dev (2022)
micha@RMS:GIS$ g.extension v.neighborhoodmatrix
Fetching <v.neighborhoodmatrix> from GRASS GIS Addons repository (be
patient)...
Compiling...
Installing...
Updating extensions metadata file...
Updating extension modules metadata file...
Installation of <v.neighborhoodmatrix> successfully finished
micha@RMS:GIS$ v.neighborhoodmatrix help
Exports the neighborhood matrix of polygons in a vector map
Usage:
v.neighborhoodmatrix [-b] input=name [player=value] [idcolumn=name]
[output=name] [separator=character] [--overwrite] [--help] [--verbose]
[--quiet] [--ui]
Flags:
-b create bidirectional matrix (same neighborhood relation repeated twice)
Hi Mohajane,
manually , but
>I couldn't use it.Could you explain what you mean by that ? What did you do and what
exactly went wrong?Moritz
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
