hellik
March 13, 2009, 12:20am
1
hi,
i'm trying the example for Network analysis: Linear reference system (LRS)
from
http://www.grassbook.org/examples3rd_chapter6.php
for the step
# add column to link the route with the bus stop
v.db.addtable route1 col="lid integer" (just copied from the website above)
and i get the following error message:
Sorry <integer"> is not a valid option
Description: [...]
the output of
db.connect -p
driver:sqlite
database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
schema:
group:
and
db.tables -p
XP_PROC
route1
stopsall
shows that the db-connection seems to be ok.
best regards
helli
osgeo4w (2008/02/08):
grass64rc3-2
GDAL 1.5.4, released 2009/01/07
data
nc_spm_08
windows vista
____________________________________________________________________
Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
Helmut:
(LRS)
from http://www.grassbook.org/examples3rd_chapter6.php for the step
above)
Most likely a small mistake in the website. Use "v.db.addcol" instead.
Regards, Nikos
Helmut Kudrnovsky ha scritto:
hi,
Please note: there is also a new LRS plugin for QGIS+PostGIS:
http://faunalia.it/qgis/plugins.xml
If you try it, please let us know.
All the best.
On Fri, Mar 13, 2009 at 1:36 AM, Nikos Alexandris
<nikos.alexandris@felis.uni-freiburg.de> wrote:
Helmut:
(LRS)
above)
No. If you look two lines above you'll see that v.category
does not copy the the table.
Please don't. It is v.db.addtable.
The example works perfectly.
I suspect an issue on Windows indeed.
PS: I have added some screenshots to
> Helmut:
>> (LRS)
>> above)
Ahh.. :-O. Sorry, my mistake. Thanks for the clarification Markus.
On 13/03/09 01:20, Helmut Kudrnovsky wrote:
hi,
i'm trying the example for Network analysis: Linear reference system (LRS) from
for the step
Could you tell us how/where you enter this command ?
Have you tried using the GUI window via the menu ?
Moritz
