[GRASS-user] Network analysis: Linear reference system (LRS) - on windows
hi nikos,
Helmut:
i'm trying the example for Network analysis: Linear reference system
(LRS)
from http://www.grassbook.org/examples3rd_chapter6.php for the step
# add column to link the route with the bus stop
v.db.addtable route1 col="lid integer" (just copied from the website
above)
Most likely a small mistake in the website. Use "v.db.addcol" instead.
Regards, Nikos
i saw this after sending the mail (it's late) ...
but i tried the example in the manual
http://grass.osgeo.org/grass64/manuals/html64_user/v.db.addcol.html
#v.db.addcol sentiero_brenta_points columns="slope double precision"
g.copy vect=busstopsall@PERMANENT,sentiero_brenta_points
     Sorry <double> is not a valid option
     Sorry <precision"> is not a valid option
or
v.db.addcol map=sentiero_brenta_points columns="slope double precision,myname varchar(15)"
   "C:/OSGeo4W/apps/msys/bin/sh.exe": -c: line 1: syntax error
   near unexpected token `varchar(1'
   `"C:/OSGeo4W/apps/grass/grass-6.4.0RC3/scripts/v.db.addcol"
    map=sentiero_brenta_points columns=\"slope double
   precision,myname varchar(15)\"'
best regards
helli
____________________________________________________________________
Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
