On 13/03/09 01:20, Helmut Kudrnovsky wrote:
hi,
i'm trying the example for Network analysis: Linear reference system (LRS)
from
http://www.grassbook.org/examples3rd_chapter6.phpfor the step
# add column to link the route with the bus stop
v.db.addtable route1 col="lid integer" (just copied from the website above)
Could you tell us how/where you enter this command ?
Have you tried using the GUI window via the menu ?Moritz
hi moritz,
i copied the command from the website in the wx-gui-commandline.
if i enter the parameters in the v.db.addtable-gui, i get the same error messages.
maybe related to http://trac.osgeo.org/grass/ticket/488
regards
helmut
____________________________________________________________________
Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
