I am studying the distribution of car accidents on a road network. In order to define hotspots and hotzones (succession of hotspots on a road) based on a local density of accidents computed on the network, I use the v.net.alloc function (to allocate a subnet to each accident event). For the moment, the density is thus expressed per “Thiessen” segment. To illustrate, Typical output is similar to
----x—|—x-|-x–|–x----
where
x: is the location of one or many accidents,
-: is a piece of the network,
|: is the limit of the Thiessen segments
My density of accident is simply the number of accident divided by the length of the Thiessen segment. Howerver, as you can notice from the example, the Thiessen segments (|—x-|) are not symmetric relatively to the accident location. I thus would like to compute the length on the right and on the left of each segment. I have tried to cut the output of v.net.alloc with v.edit and coordinates of accident but it do not works. Do you have an idea on how to proceed and which function should I use or implement?
On Mon, Aug 17, 2009 at 9:21 AM, David Dabin<david.dabin@gmail.com> wrote:
Dear Grass Users/Developpers,
density is thus expressed per "Thiessen" segment. To illustrate, Typical
----x---|---x-|-x--|--x----
where
example, the Thiessen segments (|---x-|) are not symmetric relatively to the
I think that you need a LRS (Linear Referencing System): http://grass.osgeo.org/grass64/manuals/html64_user/lrs.html
It offers "v.lrs.where" to find line id and real km+offset for given
points in vector map using linear referencing system.
Please keep us in the loop how it goes. And don't hesitate to improve
things or to suggest better documentation.
I am studying the distribution of car accidents on a road network. In order to define hotspots and hotzones (succession of hotspots on a road) based on a local density of accidents computed on the network, I use the v.net.alloc function (to allocate a subnet to each accident event). For the moment, the density is thus expressed per "Thiessen" segment. To illustrate, Typical output is similar to
where
My density of accident is simply the number of accident divided by the length of the Thiessen segment. Howerver, as you can notice from the example, the Thiessen segments (|---x-|) are not symmetric relatively to the accident location. I thus would like to compute the length on the right and on the left of each segment. I have tried to cut the output of v.net.alloc with v.edit and coordinates of accident but it do not works. Do you have an idea on how to proceed and which function should I use or implement?
