[GRASS-user] Network problem and v.net.visibility approach
Dear All,
Can this problem [1] posed on stackexchange be solved using v.net.visibility? Or I am completely wrong? I’m trying it on a dataset but it takes forever, so I can’t actually tell how the output looks like. Any other options that come on your mind?
Thanks in advance
[1] http://gis.stackexchange.com/questions/88070/identify-different-networks-inside-a-line-shapefile
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
On 28/02/14 15:58, Margherita Di Leo wrote:
Dear All,
v.net.visibility?
For those to lazy to go and look:
"I'm dealing with a quite big line shapefile containing road tracks. The roads are connected to each other, creating distinct networks. These networks are independent and they are not connected to each other.
I'm trying to find a way to identify these networks, count them and eventually measure their total length."
No. v.net.visibility connects features that are visible from each other.
Or I am completely wrong? I'm trying it on a dataset but
it takes forever, so I can't actually tell how the output looks like. Any
You might want to look into v.spanningtree or some of Daniel Bundula's network connectivity modules, notably v.net.components, although I'm not sure how both of these handle seperated parts of the network.
Or you could work with v.net.allpairs to identify all nodes connected to each other (and thus, by inverse logic all those that are not connected).
Moritz
