[GRASS-user] New AddOns for Analyzing landscape connectivity based on graph-theory - the r.connectivity.*-toolchain
Dear all,
Last week I presented a set of three new GRASS-AddOns for analyzing landscape connectivity based on graph-theory at the European Congress of Conservation Biology (ECCB, http://eccb2012.org/) in Glasgow . This set of tools applies methods documented (a.o.) in the following literature to the input data you might have.
Bunn, A. G., Urban, D. L. & Keitt, T. H. 2000: Landscape connectivity: A conservation application of graph theory. Journal of Environmental Management (2000) 59: 265-278. http://www.sciencedirect.com/science/article/pii/S0301479700903736
Calabrese, J. M. & Fagan, W. F. 2004: A comparison-shopper’s guide to connectivity metrics. Front Ecol Environ 2 (10): 529-536 . http://dx.doi.org/10.1890/1540-9295(2004)002[0529:ACGTCM]2.0.CO;2
Minor, E. S. & Urban, D. L. 2008: A Graph-Theory Framework for Evaluating Landscape Connectivity and Conservation Planning. Conservation Biology 22 (2): 297-307. http://www.uic.edu/labs/minor/minor&urban2008.pdf
Zetterberg, A., Mörtberg, U. M. & Balfors, B. 2010: Making graph theory operational for landscape ecological assessments, planning, and design. Landscape and Urban Planning (2010) 95: 181-191. http://www.sciencedirect.com/science/article/pii/S0169204610000204
Ranius, T. & Roberge, J.-M. 2011: Effects of intensified forestry on the landscape-scale extinction risk of dead wood dependent species. Biodiversity and Conservation 20 (13): 2867-2882. http://www.springerlink.com/content/ch9qtv2665h624q4
The input data the tools take are:
  • A polygon vector map containing habitat patches (of your species / habitat type in question) and a column for a population proxy (e.g. patch area). (required)
  • A cost raster map (for more information on that see the r.cost-manual) (optional; if no cost raster is provided Euclidean distance is used).
  • Dispersal information
o A maximum (cost) distance threshold for assumed connectivity
o A dispersal kernel (defined by three variables of a negative exponential decay function (see eg. Bunn et al. 2000)
The outputs are connectivity measures on vertex (=patch) level, edge (= the connection between two patches) level, and graph (the entire network) level. With r.connectivity.corridors you can also identify corridors for the connections (edges) you select, and you can weight their importance based on a column of your choice (e.g. connectivity measures from r.connectivity.network).
The tools (and documentation) can be found in the GRASS AddOns SVN repository (see: r.connectivity.distance, r.connectivity.network, r.connectivity.corridors in the http://grass.osgeo.org/wiki/GRASS_AddOns/). They are UNIX-shell (and one R-) scripts.
Required additional software is: Cran R with at least the packages “igraph” (version 0.6-2) and “nlme” installed. If you want to make use of parallel processing / multi-threading you need also the packages “doMC”, “foreach”, “iterators”, “codetools”, and “multicore”. But multithreading is only supported on LINUX. The tools have not been tested on Windows yet, but this will be done in near future.
Any kind of feedback would be very much appreciated!
Stefan
P.S.: What do you think, how helpful would an example based on the spearfish dataset be? If you think so, I will add that to the documentation, as soon as the projects which triggered the development of the r.connectivity.*-tools are published.
+1, it would be very good to have examples about this tools.
thanks!
On Fri, Sep 7, 2012 at 10:36 AM, Giovanni Manghi
Please use the North Carolina dataset which is much richer. If you
need specific data,
we can extend it which we'll do anyway for the upcoming NC dataset update.
OK, then I will add an example based on the North Carolina dataset, as soon
as I find the time for that. I do not think addidional data is necessary. I
will figure that out and come back to you if necessary.
In the meantime, I made some adjustments in the scripts, so they can be run
with WinGRASS as well. But I did not manage to add the AddOns using
g.extension under MS Windows. In this context I have two additional
questions (in order to make the AddOns available on Windows as well):
For WinGRASS version 6, additional .bat files are required in the
bin-folder. Should these bat-files be added to the svn-repository?
If the AddOns are not compiled, no html-help is build either. Should one add
a complete <module>.html to the svn repository?
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001370.html
Congratulations!
But I did not manage to add the AddOns using g.extension under
MS Windows.
(They appear to be compiled:
http://wingrass.fsv.cvut.cz/grass64/addons/grass-6.4.3svn/
I think yes, and the Makefile should take care to get them into the bin-folder.
No since this would generate double parameter entries.
You can see them in HTML mode through trac, e.g.
https://svn.osgeo.org/grass/grass-addons/grass6/raster/r.connectivity.corridors/description.html
(svn propset must be right for this, I fixed it)
MS Windows.
tried here with osgeo4w-wingrass6.4.3svn
g.extension.py extension=r.connectivity.corridors
svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
Downloading precompiled GRASS Addons <r.connectivity.corridors>...
Updating metadata file...
Installation of <r.connectivity.corridors> successfully finished
(Wed Sep 12 23:07:38 2012) Command finished (3 sec)
(Wed Sep 12 23:07:46 2012)
g.extension.py extension=r.connectivity.distance
Downloading precompiled GRASS Addons <r.connectivity.distance>...
Installation of <r.connectivity.distance> successfully finished
(Wed Sep 12 23:07:50 2012) Command finished (3 sec)
(Wed Sep 12 23:07:56 2012)
g.extension.py extension=r.connectivity.network
Downloading precompiled GRASS Addons <r.connectivity.network>...
Installation of <r.connectivity.network> successfully finished
(Wed Sep 12 23:07:59 2012) Command finished (3 sec)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001549.html
bin-folder.
AFAIK bat-files are built by addon-compilation:
C:\Users\XXXXX\AppData\Roaming\GRASS6\addons
dir /b
modules.xml
r.connectivity.corridors.bat
r.connectivity.distance.bat
r.connectivity.network.bat
the wx-gui of the 3 modules are starting, but the manual is missing in the
wx-gui; altough the html's are built and in
C:\Users\XXXX\AppData\Roaming\GRASS6\addons\docs\html
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001551.html
Dear Markus and Helmut
Thanks for the answeres!
On my OSGeo4W installation of GRASS 6.4.3svn I managed now to install the
adons using g.extension (worked only if no systemwide installation was
requested (althouh I have admin rights)).
The GUI starts and everything looks quite fine (the help is build and
available (though the chosen language is strange)). But when I run the
command I get the following message:
http://osgeo-org.1560.n6.nabble.com/file/n5001665/Message.jpg
And the processing stops...
Any ideas?
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001665.html
it doesn't find the executing shell. it's my fault, did you use g.extension
from the command line?
please try the g.extension-manager from the GUI. then precompiled
corresponding bat-files should be installed.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001677.html
Hi
I did use the g.extension-manager through the wxGUI. And both, scripts and
bat-files are in the addon-folder (within my Windows user profile). The GUI
of the addons starts and I can fill in the parameters. But after ran the
command (clicked the Run button) I get the message mentioned.
I checked if the scripts work in general by copying the scripts manually
into the script folder and the bat-files into the bin folder (after
adjusting the path to %GISBASE%)... After I did that the scripts worked
(though only through command line, through the wxGUI v.extract did not run
successful).
Probably, the addon-path (spaces in the path to my Windows user profile...)
causes trouble?
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001880.html
hi
causes trouble?
possible.
maybe do you have an example with spearfish-/nc-sample-dataset to test?
I've seen there are R and some R-packages as dependencies; maybe a short
notice in the manual would be helpfull.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001909.html
Dear Helmut, Giovanni, Markus,
Now I added an example to the manuals based on the North Carolina data set.
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5002755.html
hi Stefan,
thanks, tested now with osgeo4w-wingrass6.4.3svn in win7-64bit-box following
your example.
some issues:
(A)
manual
###Patch input vector map
##Extract habitat patches
#Condition 1: Category 11 = Bottomland Hardwoods/Hardwood Swamps
#Condition 2: no border-cells are suitable
r.mapcalc "patches=if(\
landuse96_28m[0,1]==11&&\
in windows (from the mapcalc-gui):
r.mapcalc patches =
if(landuse96_28m[0,1]==11&&landuse96_28m[0,-1]==11&&landuse96_28m[1,1]==11&&landuse96_28m[1,0]==11&&landuse96_28m[1,-1]==11&&landuse96_28m[-1,1]==11&&landuse96_28m[-1,0]==11&&landuse96_28m[-1,-1]==11&&landuse96_28m==11,1,null())
(B)
manual:
v.extract input=patches@user1 output=patches_1ha
type=point,line,boundary,centroid,area,face layer=1 where=area_ha>1 new=-1
--overwrite
maybe simplified and correctedt to?
v.extract input=patches output=patches_1ha type=area layer=1 where=area_ha >
1
(C)
r.connectivity.distance --verbose patches=patches_1ha@g65 costs=costs@g65
pop_proxy=area_ha prefix=hws_connectivity folder=C:\tmp\connect cutoff=4500
border_dist=18
Preparing boundaries...
Calculating connectivity-distances for patch number 2
C:/OSGeo4W/apps/grass/grass-6.4.3svn/scripts/r.connectivity.
distance: line 379: [: -gt: unary operator expected
distance: line 386: [: -eq: unary operator expected
Calculating connectivity-distances for patch number 13
Calculating connectivity-distances for patch number 298
(Wed Sep 19 14:59:51 2012) Command finished (5 min 49 sec)
there are a lot of these "[: -eq: unary operator expected"-messages.
following files are created:
closest.points
edges.csv
r_connectivity.log
r_connectivity.log.tmp
vertices_part_1.csv
vertices_part_2.csv
(D) some test
r.connectivity.network -y -i folder=C:\tmp\connect
connectivity_cutoff=1500.0 lnbh_cutoff=2.0 cl_thres=10 exponent=-3
kernel_plot=C:\tmp\connect\kernel.eps
overview_plot=C:\tmp\connect\overview.eps cores=1
rm: cannot lstat `C:tmpconnect/r_connectivity.log.tmp': No
such file or directory
which: R: unknown command
ERROR: R is required, please install R first
r.connectivity.network -y -i folder='C:\tmp\connect'
(Wed Sep 19 15:09:44 2012) Command finished (1 sec)
r.connectivity.network -y -i folder="C:\tmp\connect"
ERROR: r_connectivity.log file could not be found or is not readable.
=> r_connectivity.log seams not be readable
=> R is installed here on my system, but (as default by the R-installation)
not in the %PATH%
have a look how GRASS GIS-R-coupling is done by the
standalone-wingrass-installer (but not in osgeo4w-wingrass):
http://grass.osgeo.org/wiki/R_statistics#MS_Windows
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5002964.html
Dear Helumt
Many thanks for testing!
I have to admit, that I personally find it quite challenging to write a
shell-script that also works on (the different) Windows platforms (I really
should learn more Python...). On Windows everything feels less
predictable...
B)
B can be easily fixed and I shall do so ASAP.
Regarding A: Did I get you right that you had problems with the ' \ ' and '
" '? Removing the backslash won`t be a problem, but I think the
quotation-marks are required on Linux... For the latter it is probably best
to put a note in the example...
C)
C occurs because v.extract (at line 377 of the script) fails.
I assume you used the command-line in the wxPython-GUI? Could you be so kind
and try to use the command in the text version of wingrass? I managed to run
the example on Windows XP and in the text-GUI. It is a mystery to me why
some wingrass commands behave differently when invoked from the command-line
in the GUI and from the command-line (text-GUI).
Maybe the wxPython - text - GUI differences are also causing A (and D)!?
I think it would be a pitty if the GUI was not usable for these addons, but
I feel that it is beyond my power to make it work... Are there any solutions
I could use from other shell-scripts (calling v.extract)?
D)
The %PATH% settings are also a problem for ghostscript which is required for
eps-output (the plots). Because this is neither added to the %PATH%-variable
by default, I simply skipped/deactivated checking for ghostscript in windows
(here also the commands / executables can be different... :frowning: ), so checking
for ghostscript on Windows is challenging in itself.
The problem with R is, that R is called by the script (while ghostscript is
not). In other words: the script requires that the path to R is defined in
the %PATH% settings and that R can be called directly...
Maybe the best way to solve this is to add this information to the
error-message (and a link to the GRASS-R-Wiki...).
Strange that r_connectivity.log seams not to be readable. Because from your
output you posted I can see, that the file was written at the correct place.
So the path must have been interpreted correctly for writing. I have no idea
why it is obviously not interpreted correctly for reading... I will check
that...
Best regards
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5003029.html
hi Stefan,
de nada
this isn't possible in the wxgui-commandline (not tried in the
wingrass-windows-commandline; most users on windows probably are using only
the GUI)
Removing the backslash won`t be a problem, but I think the quotation-marks
are required on >Linux...
unfortunately there seams to be inconsistency between
unix/windows/GUI/commandline
For the latter it is probably best to put a note in the example...
sure, but better feel free to open a ticket for this in
http://trac.osgeo.org/grass/, because otherwise it's getting lost in
manual/ML and other modules/scripts etc. are able to benefit
C)
yes
Could you be so kind and try to use the command in the text version of
wingrass?
sure, but unfortunately the same message:
Calculating connectivity-distances for patch number 279
C:/OSGeo4W/apps/grass/grass-6.4.3svn/scripts/r.connectivity.distance: line
379:
386:
100%
100%
Calculating connectivity-distances for patch number 294
379:
386:
100%
100%
379:
386:
100%
100%
GRASS 6.4.3svn (nc_spm_08)>
It is a mystery to me why some wingrass commands behave differently when
invoked from the >command-line in the GUI and from the command-line
(text-GUI).
...windows itself is a mystery...not only the differences between XP, Vista,
7 and soon 8
I feel that it is beyond my >power to make it work... Are there any
solutions I could use from other shell-scripts (calling >v.extract)?
feel free to post this issue separately on the dev-ML or open a ticket in
for eps-output (the >plots).
adding the ghostscript-%PATH%-issue to the manual?
Because this is neither added to the %PATH%-variable by default, I simply
skipped/deactivated checking for ghostscript in windows (here also the
commands / executables >can be different... :frowning: ),
the windows mystery...
so checking for ghostscript on Windows is challenging in itself.
not). In other words: the >script requires that the path to R is defined in
the %PATH% settings and that R can be called >directly...
error-message (and a link to the >GRASS-R-Wiki...).
in the standalone winGRASS6.5svn/winGRASS7-installer there is the new
approach of R-winGRASS-coupling by the "Windows batchfiles for use with R"
mentioned in the wiki
(http://grass.osgeo.org/wiki/R_statistics#GRASS_7_Usage), in the upcoming
standalone winGRASS6.4.3(svn) there is the old statically approach
(http://grass.osgeo.org/wiki/R_statistics#GRASS_6_Usage_III_.28taken_from_the_grass-stats-ML.29)
because of "nearly" feature freeze.
in short, in the standalone-winGRASSX.x.x, R should in the %PATH%
in the osgeo4w-winGRASSX.x.x R isn't yet in the %PATH%.
please feel free to open a ticket in http://trac.osgeo.org/grass/ to change
this.
output you posted I >can see, that the file was written at the correct
place.
yes
correctly for writing. I have no idea why it is obviously
check that...
no idea at the moment for this.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5003035.html
Hi again
Now I added som bugfixes for the issues Helmut came across.
A and B are changed in the manual.
For issue C (unary operator expected) it was too simple to blame
Microsoft... (Sorry for that, Bill.) And it was no problem with v.extract
either. Actually, it was my fault, because I tried to catch the number of
centroids from the secondary output of v.extract using grep. But due to
translation, centroids are not allways called "centroids", so grep did not
find anything on my german system... Now I use v.info for that. This means
an extra command in the loop but it should work now (independend from
language settings).
The R-path issue is tackled (for the time being) by adjusting the error
message until a more general solution is found... In other words, users have
to add the path to R into their environment settings (if that has not been
done before) in order to make the AddOn usable.
R can be installed where so ever on the system, so looking for R is not too
easy (or fast)...
Furthermore a requirement section is added to the manual of
Stefan
By the way:
a) Does anyone know if xargs also works with wingrass? Alternatives?
b) Hints for a convenient parallel processing solution in R which also works
on Windows (alternative or in addition to multicore and doMC on Linux) would
be most welcome...
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5003434.html
