[GRASS-user] New AddOns for downloading and importing Sentinel products
today I have uploaded a new toolset for downloading and importing
Sentinel products, namely two modules:
r.sentinel.download [1] and r.sentinel.import [2].
The first module requires Sentinelsat and Pandas library, the second
GDAL with OpenJPEG.
Testing and feedback welcome! Enjoy, Ma
[1] https://grass.osgeo.org/grass72/manuals/addons/r.sentinel.download.html
[2] https://grass.osgeo.org/grass72/manuals/addons/r.sentinel.import.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Fri, Jan 26, 2018 at 11:36 PM, Martin Landa <landa.martin@gmail.com> wrote:
GDAL with OpenJPEG.
Cool!
I was able to successfully select and download S2 scenes for the North
Carolina area.
Do you plan to add reprojection on the fly through r.import?
thanks, Markus
BTW: Last year we created a portal for ESA which let's you filter
Sentinel-2 scenes by extra metadata derived from open data:
  Earth Observation metadata enhancer (EO-me)
  https://sentinel.esa.int/web/sentinel/-/filter-sentinel-2a-scenes-with-the-new-release-of-eo-me
  https://eome.mundialis.de
It meanwhile also supports Sentinel-2B and comes with an OpenSearch interface:
https://eome.mundialis.de/eomedocs/opensearch.html
Hi Markus,
2018-01-28 20:45 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
r.sentinel.import -o
Interesting, Ma
Martin Landa
Hi Martin,
On Sun, Jan 28, 2018 at 9:01 PM, Martin Landa <landa.martin@gmail.com> wrote:
Hi Markus,
I see. Perhaps I got confused because without -o it tells me:
       In case of no significant differences in the projection definitions,
       use the -o flag to ignore them and use current location definition.
       Consider generating a new location from the input dataset using the
       'location' parameter.
So it would be good to suppress this message which likely comes from a
r.in.gdal call and replace it with one related to
  -o Reproject raster data using r.import if needed
Would that be possible?
thanks
Hi Martin,
the reprojections is done when using -o (as advertised in the flag description).
A related idea, if you don't mind:
GRASS 7.4.1svn (nc_spm_08_grass7):~ > r.sentinel.import
input=/home/mneteler/tmp/ pattern='B0[4|8]' -o
Estimated target resolution for input band <T17SQV_20180124T160541_B04>:
9.79587588067
It would probably be best to fetch the nominal resolution from the S2
band description and apply that rather than estimating it (at least,
most users will expect to get 10m in this example). Or, optionally
make it a flag like e.g. "-k keep nominal band resolution when in
metric CRS" or similar which could then also imply bilinear resampling
rather than the standard nearest neighbor resampling.
Just an idea,
Hi Martin,
Very nice work! This will simplify some of my workflows significantly!
One parameter I was missing was however "area_relation". Please find attached a diff, in case you agree that it would be a useful addition (the python script is successfully tested, though I did not check the html changes).
Two things I was wondering are:
1. it might make sense to also provide the "url" as an option, cause there are some national mirrors of ESAs scihub around (at least this is the case for Norway) that expose the same API but are faster / cause have less traffic. What do you think?
2. the tools currently only support Sentinel-2, right. Do you plan to extend them to Sentinel-1/3... in future?
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Martin Landa
Sent: fredag 26. januar 2018 23.36
To: GRASS users list <grass-user@lists.osgeo.org>
Subject: [GRASS-user] New AddOns for downloading and importing Sentinel products
today I have uploaded a new toolset for downloading and importing Sentinel products, namely two modules:
The first module requires Sentinelsat and Pandas library, the second GDAL with OpenJPEG.
Martin Landa
grass-user mailing list
(attachments)
r.sentinel.diff (2.99 KB)
Hi Markus,
2018-01-28 21:15 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
done, projection check is done by `r.in.gdal -j`. I have also rename
-o flag to -r. Flag -o is used for overriding projection check which
is this case. Ma
Martin Landa
2018-01-28 21:36 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
implemented in r72198 by reading input file using GDAL.
I would prefer avoid adding new flags if not necessary :slight_smile: Ma
Martin Landa
Hi Stefan,
2018-01-29 9:11 GMT+01:00 Stefan Blumentrath <Stefan.Blumentrath@nina.no>:
nice to hear.
Patch applied (r72199)
Would make sense.
In future :slight_smile: Ma
PS: Patches welcome :slight_smile:
Martin Landa
On 26/01/18 23:36, Martin Landa wrote:
GDAL with OpenJPEG.
Shouldn't these be better called i.sentinel.* ? They are clearly imagery related.
Moritz
2018-02-16 16:17 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
related.
you are probably right. Than we should also rename r.modis and
probably also other modules. What do you think? Ma
Martin Landa
On 16/02/18 19:12, Martin Landa wrote:
related.
+1
Concerning r.sentinel.download: A colleague has been trying to use it under windows, but:
- installing GRASS using osgeo4w gives you sentinelsat, but pandas doesn't seem to be installed in the correct version as with
import pandas
you get an error message about a missing natype module (something like that, am not at the windows computer, now).
- installing GRASS using the standalone installer, my colleague has difficulty installing sentinelsat as 'pip install sentinelsat' fails
Has anyone else tried this on Windows ?
import pandas
quick test here on my OSGeo4W 64bit:
run o-help for a list of available commands
C:\>python
Python 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
import pandas
no problem here to import pandas
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
related.
+1
under windows, but:
import pandas
P.S.
I consider it unideal practice to write passwords in clear on the command line. I don't know if it would be very complicated to work with a sentinel scihub password file...
Moritz
tested here with
GRASS version: 7.4.0
GRASS SVN revision: r72154
Build date: 2018-01-27
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
r.sentinel.download -l user=myusesr password=mypwd
1a51afeb-9d18-410a-aec3-2366cfe22d81 2018-01-24T10:13:09Z 10% S2MSI1C
e6cda378-d2e4-4c9c-809f-524b3a354ec2 2018-01-29T10:12:51Z 12% S2MSI1C
84b5b211-69a8-4f96-beae-02ff05e87d36 2017-12-22T10:04:19Z 19% S2MSI1C
6fc7a685-971c-49ef-ad86-b993ef644b2a 2018-02-10T10:01:39Z 19% S2MSI1C
e64633ea-d302-49c7-a7ed-fdbf143b3b2f 2017-12-25T10:14:19Z 24% S2MSI1C
5 Sentinel product(s) found
no time to test the download itself at the moment
best regards
Helmut
ok, tested also the dowload itself:
r.sentinel.download user=myuser password=mypwd output=D:\dl\sentinel
map=myriver@data start=2018-01-20 end=2018-01-27 limit=1
1 Sentinel product(s) found
Downloading data into <D:\dl\sentinel>...
1a51afeb-9d18-410a-aec3-2366cfe22d81 ->
D:\dl\sentinel\S2B_MSIL1C_20180124T101309_N0206_R022_T33TUM_20180124T190119.SAFE
Downloading: 0%| | 0.00/885M [00:00<?, ?B/s]
Downloading: 0%| | 1.05M/885M [00:02<30:27,
484kB/s]
Downloading: 0%| | 2.10M/885M [00:04<29:58,
491kB/s]
Downloading: 0%| | 3.15M/885M [00:08<37:55,
388kB/s]
Downloading: 0%| | 4.19M/885M [00:11<38:13,
384kB/s]
Downloading: 1%| | 5.24M/885M [00:13<36:07,
406kB/s]
Downloading: 1%| | 6.29M/885M [00:15<33:18,
440kB/s]
Downloading: 1%| | 7.34M/885M [00:18<37:31,
390kB/s]
Downloading: 1%| | 8.39M/885M [00:21<37:45,
387kB/s]
seems also to work so far.
best regards
Helmut
2018-02-19 14:22 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
what is a structure of such file? Thanks for pointers, Ma
Martin Landa
Le Mon, 19 Feb 2018 20:13:51 +0100,
Martin Landa <landa.martin@gmail.com> a écrit :
Following the example of .pgpass for PostgreSQL, it could be a simple
text file with:
login:password
and the module would only use it if it is chmod 600, i.e. only readable
by the owner.
Moritz
On Mon, Feb 19, 2018 at 4:49 PM, Moritz Lennert <
by the owner.
...and the code to test that (user behaves safely) should be somewhere in
g.cloud and/or g.remote:
https://trac.osgeo.org/grass/browser/grass-addons/grass7/general/g.cloud
https://github.com/wenzeslaus/g.remote
On 20/02/18 01:24, Vaclav Petras wrote:
On Mon, Feb 19, 2018 at 4:49 PM, Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
    by the owner.
...and the code to test that (user behaves safely) should be somewhere in g.cloud and/or g.remote:
I suppose you mean should _also_ be ?
Moritz
