[GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
Dear user list,
The (main) GRASS GIS executable, usually available as simply grass on most systems has now a new option (flag/parameter) in trunk (aka 7.5). The option is called --tmp-location.
When specified, GRASS GIS automatically creates an new (and empty) location based on provided EPSG code or georeferenced file (similarly to what -c flag does). Newly it is also possible to provide string “XY” instead of EPSG to create XY (non-georeferenced) location.
This temporary location has only PERMANENT mapset and the whole location is removed. The location is created in a temporary directory (which is also deleted at the end).
The flag --tmp-location is meant to be used together with --exec and it is a part of a lager endeavor to make the CLI easier for use from outside of the GRASS GIS session.
If you are interested, please, test this new functionality. It is an opportunity to provide feedback before this feature lands in the 7.6 release.
Here are some things to try:
  • Execute a module in a location created based on EPSG:
grass --tmp-location EPSG:3358 --exec g.region -p
  • Execute Python script in a location created based on EPSG:
grass --tmp-location EPSG:3358 --exec script.py
  • Examine the created location using a Bash command:
grass --tmp-location EPSG:3358 --exec bash -c “g.proj -p && g.region -p && g.mapset -p && g.gisenv GISDBASE,LOCATION_NAME sep=/”
  • Get SRS/CRS for a file:
grass --tmp-location ~/data/elevation.tiff --exec g.proj -p
  • Get help text for a module:
grass --tmp-location XY --exec r.neighbors --help
See the documentation and grass --help for more hints (and let me know how these can be enhanced).
Best regards,
Vaclav
https://trac.osgeo.org/grass/ticket/3537
https://trac.osgeo.org/grass/ticket/3585
https://trac.osgeo.org/grass/ticket/3586
https://trac.osgeo.org/grass/changeset/72790
https://trac.osgeo.org/grass/changeset/73096
https://trac.osgeo.org/grass/changeset/73098
https://trac.osgeo.org/grass/changeset/73099
Thanks Vaclav,
Looks like a great enhancement. It should make it easy to wrap it into
a R package for example.
One question -- is that possible to refer to the input dataset in the
script called
by --exec? Something like:
grass --tmp-location ~/data/elevation.tiff --exec "r.param.scale
in=myinput out=myoutput param=slope size=9"
P
On 15 August 2018 at 15:20, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear user list,
The (main) GRASS GIS executable, usually available as simply `grass` on most
does). Newly it is also possible to provide string "XY" instead of EPSG to
GRASS GIS session.
release.
* Execute a module in a location created based on EPSG:
* Execute Python script in a location created based on EPSG:
* Examine the created location using a Bash command:
  grass --tmp-location EPSG:3358 --exec bash -c "g.proj -p && g.region -p &&
g.mapset -p && g.gisenv GISDBASE,LOCATION_NAME sep=/"
* Get SRS/CRS for a file:
* Get help text for a module:
See the documentation and `grass --help` for more hints (and let me know how
Best regards,
Vaclav
grass-user mailing list
grass-user@lists.osgeo.org
Dear Pierre,
Just in case you are not aware of it, GRASS and R integrate very nicely:
https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Pierre Roudier
Sent: torsdag 16. august 2018 10:07
To: Vaclav Petras <wenzeslaus@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
Thanks Vaclav,
Looks like a great enhancement. It should make it easy to wrap it into a R package for example.
One question -- is that possible to refer to the input dataset in the script called by --exec? Something like:
grass --tmp-location ~/data/elevation.tiff --exec "r.param.scale in=myinput out=myoutput param=slope size=9"
P
Dear user list,
"XY" instead of EPSG to create XY (non-georeferenced) location.
release.
-p && g.mapset -p && g.gisenv GISDBASE,LOCATION_NAME sep=/"
Best regards,
Vaclav
Thanks Stephan,
I'm aware of rgrass7 and spgrass6 -- I had in mind a package a lot
lighter, that basically "hides" the specificities of GRASS (eg the
notions of GRASSDATA, of locations, of mapsets...) from the user, and
just run a GRASS command on a GDAL/OGR type file.
P
On 16 August 2018 at 20:37, Stefan Blumentrath
<Stefan.Blumentrath@nina.no> wrote:
Dear Pierre,
Stefan
Thanks Vaclav,
P
Dear user list,
release.
Best regards,
Vaclav
* Vaclav Petras <wenzeslaus@gmail.com> [2018-08-14 23:20:16 -0400]:
release.
Perhaps test if the file exists and, if not, exit with an informative error
message?
In Python:
import os.path
os.path.isfile(fname)
Currently, if the file does not exist, the process hangs:
Cleaning up temporary files...
Starting GRASS GIS...
Best regards,
Vaclav
All works.
Fantastic work!
Kudos Radek and Vaclav,
Nikos
On Thu, Aug 16, 2018 at 6:39 AM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
release.
message?
In Python:
import os.path
Hi Nikos,
sounds good to me. Do you want to submit an issue and suggest a patch?
Vashek
Best regards,
Vaclav
All works.
Fantastic work!
Nikos
On Thu, Aug 16, 2018 at 4:06 AM, Pierre Roudier <pierre.roudier@gmail.com> wrote:
Thanks Vaclav,
You are welcome. I hope it will be helpful.
Yes, the idea for this is that it also should make easy to wrap GRASS GIS in whatever you want.
One question – is that possible to refer to the input dataset in the
script called
grass --tmp-location ~/data/elevation.tiff --exec “r.param.scale
in=myinput out=myoutput param=slope size=9”
This makes sense since the GUI Startup (and/or Location Wizard) have this functionality (also importing the file after using its SRS). However, this is effectively an API and needs more considerations. How would you suggest to deal with the output when --tmp-location ~/data/elevation.tiff creates location with elevation raster but than myoutput is deleted with the rest of the location? What about multiple inputs?
At this point, I’m hoping we can move forward through individual issues and use cases (rather than revamping CLI altogether), so you remarks fall into that well. Please, feel to submit an enhancement ticket ideally with a use case, so we can discuss it there.
Please see also a little write-up I did for GSoC idea some time ago:
https://trac.osgeo.org/grass/wiki/GSoC/2018#Neweasy-to-useCLIandAPIforGRASSGIS
Best,
Vaclav
P
Dear user list,
GRASS GIS session.
release.
Best regards,
Vaclav
Nikos:
message?
In Python:
import os.path
Hi Nikos,
Vashek
https://trac.osgeo.org/grass/ticket/3537#comment:8
[rest deleted]
Nikos
