[GRASS-user] new error window
Hi
After yesterday updating of grass CVS new issue in tcl/tk gui appears:
when I refresh display window, completly new window (looks like r.info message) appears with following message:
<map> is not correct parameter (or simillar, massage is in polish)
ERROR requiered parameter of <INPUT> is not set .....
next is r.info help text
how to switch off this massage (where in code)? After several clicks it became frustrating....
Jarek
Those errors are related to some changes I did to gis.m, which are the
"info" buttons for raster and vector in gis.m.
For some reason, they are not working in the cvs. If I replace
raster.tcl and vector.tcl for the version that is attached, it works.
The attached version also adds a button for "set region to map"
(raster and vector). I use it a lot, I don't know if it would be of
general interest.
If you want to try, just replace the .tcl files in $GISBASE/etc/gm
with the ones in the attachment, and add the icons to
$GISBASE/gui/icons
Carlos
On 9/17/07, Jarek Jasiewicz <jarekj@amu.edu.pl> wrote:
Hi
Jarek
grassuser mailing list
grassuser@grass.itc.it
              Carlos Henrique Grohmann - Guano
  Visiting Researcher at Kingston University London - UK
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
(attachments)
gism_addon.zip (9.37 KB)
6.2 or 6.3? I assume 6.3.
gis.m or d.m? I assume gis.m.
I'm not using GRASS polonized, but in my English speaking instalation
no such problem occurs in gis.m or d.m. What do you exactly mean by
"refresh display window". Button "Display active layer", "Redraw all
layers" in gis.m or something else?
Maciek
general interest.
$GISBASE/gui/icons
Carlos
Hi
Jarek
thanks Carlos I tried It works.
Set region to map seems to be good idea. Anyway, it not disturb :slight_smile:
Jarek
