[GRASS-user] new map in wxgui digitizer
Friends,
   I am trying to make use of the wxgui digitizer and finding it somewhat challenging. One issue is that I like to run from the console (i.e. grass73 -text) and that produces a subtly different widget than if I run from the gui (i.e. grass73 -gui). Using the console version, when I try to digitize a new map (as opposed to editing an existing map) I get the error below.
GRASS GIS 7.3.svn > Traceback (most recent call last):
   File "/usr/local/grass-7.3.svn/gui/wxpython/vdigit/toolbars.py", line 849, in OnSelectMap
     if self.layers[selection] == self.mapLayer:
UnboundLocalError: local variable 'selection' referenced before assignment
and it doesn't digitize any points.
The obvious short term solution is to work from the GUI, but that defeats much oswhat I am trying to accomplish in scriptable, repeatable analyses.
GRASS GIS 7.3.svn (r69510)
Linux luthertucker 4.8.7-1-ARCH #1 SMP PREEMPT Thu Nov 10 17:22:48 CET 2016 x86_
Thanks, Dave
On Fri, Nov 18, 2016 at 10:41 AM, Dave Roberts <droberts@montana.edu> wrote:
Friends,
in OnSelectMap
x86_
Thanks, Dave
That's a bug we should fix before release (if it's in 72). I don't
remember, are you able to create a ticket now?
Anna
grass-user mailing list
grass-user@lists.osgeo.org
Hi Anna, yes I can create tickets now. I'll do that this weekend.
Thanks, Dave
Friends,
in OnSelectMap
x86_
Thanks, Dave
Anna
