[GRASS-user] New modules in add-ons: v.in.geoplot, r.xtent + r.burn.frict
I have added some new modules to the Add-ons repository:
http://grass.osgeo.org/wiki/GRASS_AddOns#v.in.geoplot
http://grass.osgeo.org/wiki/GRASS_AddOns#r.burn.frict
http://grass.osgeo.org/wiki/GRASS_AddOns#r.xtent
Descriptions:
v.in.geoplot converts a Geoplot 3 ASCII export file to a GRASS vector map layer.
r.burn.frict converts vector geometries to raster cells, using a simple anti-aliasing method to close "gaps" between diagonal cells. Useful for "burning" vector geometries into a friction surface, making sure that simulated movement does not "slip" through converted cells that have only diagonal neighbours.
r.xtent computes a raster map layer representing the Voronoi diagram, weighted Voronoi diagram or a more complex territorial partitioning of space around points (centers) in a vector input map, based on the XTENT formula.
r.burn.frict and r.xtent are really intended to go together for creating realistic territorial models.
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
On Mon, Sep 28, 2009 at 4:26 PM, Benjamin Ducke
Hi Benjamin,
out of curiosity: what's the difference to r.carve?
