Hi!
On Sun, 2008-12-07 at 15:08 -0800, mtnbiketrail@zzz.com wrote:
I'm using 6.3 on Ubuntu with QGIS.
If I create a new location, under PERMANENT,
The PERMANENT mapset is created automatically for each new LOCATION.
However, you cannot create a (new) LOCATION *under* the PERMANENT
mapset.
(Something like... LOCATION > Mapset(s) )
does that coordinate system
that I specify for PERMANENT the default coord sys for a new mapset I
create under that location?
Yes. Each new mapset within a pre-defined LOCATION (of some coordinate
reference system) will obtain the (same) defined cooridante reference
system.
I have different raster and vector maps I
want to use and they are all different coord systems. Can I have a
different coord system for each mapset?
I don't think so. You need to create as many LOCATIONS as your different
coordinate reference systems in which your geodata are
"projected/defined".
For the DATABASE parameter, is GRASS smart enough to add on the LOCATION
directory.
Yes, by default grass uses the dbf under
"$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" [1]. I always change it (to use
sqlite) and don't really "remember" if the creation of a new mapset will
create a new "bdf" directory in it. But it should
Anyhow, you need to use db.connect in order to define which DBMS you
want to use and where you want to store the database.
IS the DATABASE always the same, even if I create different
LOCATIONS?
I think not. It's not *correct* (?) to use the same database (of some
location) directly from another location.
I had some trouble when I did that once (I was experimenting): I messed
up let's say "original" data stored in the PERMANENT with edited data on
another mapset/ another location by using the same name.
Perhaps somebody with more experience can give his valuable view upon
the subject.
So should I create the PERMANENT coord system with what I want to use(
which is wgs84 UTM).
You probably need a LOCATION defined by the WGS84 (epsg=4326) geographic
coordinate system. In the PERMANENT mapset (within your newly created
LOCATION) will be imported all data initially. Then, it is a good
practice (but not a MUST) you probably would like to create another,
user-mapset (your own mapset), copy over the data (from the PERMANENT to
YourMapset) and start playin with your data.
So I can use QGIS and its "on the fly" option.
Don't understand here/ Don't know the answer.
I tried to do this with the text based interface, but kept getting weird
stuff, like ESC+ENTER didn't always work.
Which operating system do you work with?
Regards, Nikos
[1] http://grass.osgeo.org/grass64/manuals/html64_user/db.connect.html
