[GRASS-user] Newbie adding additional modules?
Hello,
It has been nearly 16 years since I used Grass and now coming back. I have
GRASS up and running on my Mac PowerBook G4 with OS X 10.4.6
Now I am trying to install the r.out.netcdf module and am at a loss as to
how to go about it. Any help would be appreciated.
Barry
_________________________
Barry Baker, Ph.D.
Global Climate Change Initiative
The Nature Conservancy
2424 Spruce St., Suite 100
Boulder, CO 80302
Tel: (303)-541-0322
Fax: (303)-449-4328
http://nature.org/tncscience/scientists/misc/baker.html
I have GRASS up and running on my Mac PowerBook G4 with OS X 10.4.6
to how to go about it. Any help would be appreciated.
Unless r.out.netcdf is packaged for the new GRASS 6.1 Extension Manager
(GEM), and I'm pretty sure it isn't, you will need the full grass source
code to compile it.
after ./configure, make of source code,
mkdir raster/r.out.netcdf/
cd raster/r.out.netcdf/
cp r.out.netcdf_source_files/* .
make
alternatively and probably simpler, use r.out.gdal for NetCDF output:
GRASS> gdalinfo --formats
  GMT (rw): GMT NetCDF Grid Format
  netCDF (ro): network Common Data Format
In my old version of GDAL, the GMT version is only one which it can
write to. I'm not sure what the latest version can do.
http://www.gdal.org/formats_list.html
another indirect way is to use r.out.mat to make a Matlab array and
to save a NetCDF file from there. (r.out.mat is untested on big-endian
AFAIK, if that doesn't work use raw r.out.bin -> Matlab)
If you are looking to send output to GMT, there are other options &
scripts that can be used. see r.out.gmt on the wiki add-ons page and:
http://169.237.35.250/~dylan/grass_user_group/#GMT_and_GRASS-overview
Hamish
Copy the r.out.netcdf module into the ~/grass-6.0.0/raster/ source directory
Create a Makefile in the r.out.netcdf directory if there doesnt exist one, and then run
"make" . If the Makefile already exist, make sure -lnetcdf is added to the LIBES
The following is the Makefile:
MODULE_TOPDIR = ../..
PGM = r.out.netcdf
LIBES = $(D_LIB) $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) -lnetcdf
DEPENDENCIES= $(D_DEP) $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Hamish wrote:
Barry Baker wrote:
It has been nearly 16 years since I used Grass and now coming back. I have GRASS up and running on my Mac PowerBook G4 with OS X 10.4.6
code to compile it.
make
Hamish
grassuser mailing list
grassuser@grass.itc.it
Another route that does not involve recompiling GRASS is to write a Python script to export the data from GRASS into an ASCII format, read the data into a numeric python array (NumPy) and then use the included netCDF module in NumPy to create your netCDF:
http://www-md.fsl.noaa.gov/eft/developer/netCDFPythonInterface.html
one, and then run
“make” . If the Makefile already exist, make sure -lnetcdf is added to
the LIBES
MODULE_TOPDIR = …/…
PGM = r.out.netcdf
default: cmd
(GEM), and I’m pretty sure it isn’t, you will need the full grass source
code to compile it.
make
write to. I’m not sure what the latest version can do.
AFAIK, if that doesn’t work use raw r.out.bin → Matlab)
Hamish
David Finlayson
Thank you Hamish, David and Nagesh for your prompt suggestions on how to fix
my problem with outputting Netcdf files.
Best,
Barry
code to compile it.
make
Hamish
Barry Baker, Ph.D.
Boulder, CO 80302
Tel: (303)-541-0322
Fax: (303)-449-4328
