I have just started writing scripts using python for Grass on Mac. I copied
the example below from the library and ran it.
#!/usr/bin/env python
#%module
#% description: Checks if vector map is 3D
#% keywords: vector
#%end
#%option
#% key: map
#% type: string
#% gisprompt: old,vector,vector
#% key_desc: name
#% description: Name of vector map
#% required: yes
#%end
import sys
import grass.script as grass
def main():
info = grass.parse_command('v.info',
flags = 't',
map = options['map'])
return 0
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
When I ran the program using the GUI, it gave me an error without
explanation, so I tried the command line running from inside the Grass:
"python hi.py map=geology@PERMANENT"
and I got the following error:
"execl() failed: Permission denied"
I would appreciate if anyone can help.
Ahmad
View this message in context: http://n2.nabble.com/Newbie-running-python-on-Mac-error-on-execl-tp4860279p4860279.html
