[GRASS-user] Newbie with composite raster import
Please excuse my newbiness. I have been reading documentation left, right
and centre and I may be missing something but I can't find an obvious way
to do this.
I have a set of high resolution digital maps (currently a matrix of about
200x400, each at 1280x1024 resolution). They are saved as GIF files,
though that could be changed, and I know their centre and edge positions
in terms of Lat/Long to a negligible error. These data are stored in a
tab-delimited text file. The map fragments are in a transverse mercator
projection though not UTM. They are plain image files with no geographic
data geocoded into the format.
What I want to do is to import them automatically via shell-scripted
commands to a Grass raster layer(s?) in order to cover the region over
which they spread, so that within grass I can work with it as a contiguous
area.
I have found information about importing scanned maps with graphical
picking of corners but this is both far too time consuming and unnecessary
for what I am attempting (the maps are 'square', not scanned, and I can
provide their edge positions automatically). I have also found some
indications that each raster image has to end up as its own layer... how
does this work with groups, large numbers of map fragments etc? Do I have
to join the raster images within Grass or can they be kept separate?
If someone could point me in the right direction in terms of which
commands I need to use and whether this is possible, I'd be very grateful.
I'm really looking forward to getting this lot into Grass so that I can
start working with it and learning more!
Many many thanks in advance,
Adrian
to do this.
area.
To set the bounds of the imported maps, use r.region.
To merge multiple maps, use r.patch. If the images don't share a
common colour table (palette), you will probably need to recode them
first.
