[GRASS-user] No color for geotiffs exported with r.out.gdal
Hello,
I am using GRASS 6.4~rc5-2 on Ubuntu 9.10. I am trying to export a DCELL
raster map to both a byte formatted and a UInt16 formatted Geotiff file.
The UInt16 formatted file shows nothing when I try to open the file, and
the byte formatted file is in black and white only. I can't seem to get
color. The original GRASS raster uses the "ndvi" color scheme.
Thanks, Bill
How about r.out.tiff?
Mark
On Fri, Apr 2, 2010 at 11:00 AM, William Hudspeth <bhudspeth@edac.unm.edu> wrote:
Hello,
the byte formatted file is in black and white only. I can’t seem to get
color. The original GRASS raster uses the “ndvi” color scheme.
Thanks, Bill
grass-user mailing list
grass-user@lists.osgeo.org
I have tried that too with the same results...
Thanks though,
Bill
Mark
        Hello,
        export a DCELL
        Geotiff file.
        file, and
        seem to get
        Thanks, Bill
On Fri, Apr 2, 2010 at 5:00 PM, William Hudspeth <bhudspeth@edac.unm.edu> wrote:
Hello,
NDVI ranges (theoretically) from -1 to +1. Hence not much information
would survive then stored in 0..255 (8 bit) or 0..65535 (16bit UInt).
Solutions are
- select Float32 (but GeoTIFF won't support a color table)
- Add +1 and multiply with 100 and adjust the color table accordingly,
then export to 8bit
- choose a different format which supports color tables in floating
point format,
  check http://www.gdal.org/formats_list.html
- maybe more...
Please post your solution here.
Mark
Another (strange) option is to export with "r.out.ascii" and convert
into GeoTIFF with gdal_translate. For example, given that your ascii
rasters have ".asc" extension:
for x in *.asc; do gdal_translate (your-options-go-here) $x $x.tif; done
(Don't remember from where I stole this hint).
Nikos
        Hello,
        export a DCELL raster map to both a byte formatted and a
        file, and the byte formatted file is in black and white only.
        I can't seem to get color. The original GRASS raster uses the
        Thanks, Bill
Markus,
Thanks for your assistance and explanation. I ended up adding +1 and
multiplying by 100 the source raster....
e.g.
r.mapcalc "new_raster=(old_raster+1.0)*100"
I also transformed the ndvi color table accordingly, and post it here if
anyone should wish to use it...
0.00 5 24 82
70.0 5 24 82
82.0 255 255 255
100.0 255 255 255
102.5 206 197 180
107.5 191 163 124
112.5 179 174 96
115 163 181 80
117.5 144 170 60
123.3 166 195 29
126.6 135 183 3
133.3 121 175 1
136.6 101 163 0
143.3 78 151 0
146.6 43 132 4
155.0 0 114 0
165.0 0 90 1
175.0 0 73 0
185.0 0 56 0
195.0 0 31 0
200.0 0 0 0
Thanks, Bill
On Fri, 2010-04-02 at 23:10 +0200, Markus Neteler wrote:
<grass-user@lists.osgeo.org>
William Hudspeth wrote:
Markus,
e.g.
Bill:
Looks like a good candidate for the GRASS wiki, if you don't mind.
0.00 5 24 82
70.0 5 24 82
82.0 255 255 255
100.0 255 255 255
102.5 206 197 180
107.5 191 163 124
112.5 179 174 96
115 163 181 80
117.5 144 170 60
123.3 166 195 29
126.6 135 183 3
133.3 121 175 1
136.6 101 163 0
143.3 78 151 0
146.6 43 132 4
155.0 0 114 0
165.0 0 90 1
175.0 0 73 0
185.0 0 56 0
195.0 0 31 0
200.0 0 0 0
Thanks, Bill
This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
