First of all, I’m new to this mailinglist and to GrassGIS in general.
So, I’m trying to use the r.sunmask command in order to extract the shadow from an SRTM DEM of the Alps mountains (Switzerland).
The image had to be first reprojected when I’ve imported it to a EPSG:21781 location, in order to get both the (lat, lon) in meters (similarly to the elevation).
Here is the command I’m executing (note that the time of the day was chosen at 09:00 in the morning to maximize the shadow):
The problem I have is that the image produced is emtpy (no-data everywhere).
Is there a parameter I’m forgetting to add to the r.sunmask command?
Or should I use r.sun command instead, even though I’m not sure about the parameters I should provide to it either ?
First of all, I'm new to this mailinglist and to GrassGIS in general.
So, I'm trying to use the `r.sunmask` command in order to extract the
shadow from an `SRTM DEM` of the Alps mountains (Switzerland).
The image had to be first `reprojected` when I've imported it to a
`EPSG:21781` location, in order to get both the (lat, lon) in meters
Here is the command I'm executing (note that the time of the day was
chosen
everywhere).
Is there a parameter I'm forgetting to add to the `r.sunmask` command?
Or should I use `r.sun` command instead, even though I'm not sure about
the
Hakim.
have you set your computional region to your DEM by g.region?
Welcome Most likely you need to set the region to your DEM. FAQ #1 when using GRASS: Always set the region first
On 09/04/2017 05:15 PM, Hakim Benoudjit wrote:
Hello,
`g.region -p ```rast=n46_e006_1arc_v3@PERMANENT``
Hakim.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Thanks guys for the quick response.
You were right, the shadow wasn’t detected because the region hasn’t been set.
Now it seems to be working, but I’m wondering between r.sunmask and r.sun which one should be used to calculate the shadow mask?
Thanks.
Hakim.
Hello,
Hakim.
