Friends,
I compiled grass_7.8.3from source to run on arch linux (the AUR version is broken). Compiled and installed fine. Still have problems though.
d.rast relief
File "/home/dvrbts/grass/rmveg/PERMANENT/.tmp/luthertucker/MONITORS/wx1/render.py", line 6, in <module>
from grass.script import core as grass
File "/usr/local/grass78/etc/python/grass/__init__.py", line 4, in <module>
import six
ImportError: No module named six
find /usr/local/grass78 -name six.py
/usr/local/grass78/gui/wxpython/mapdisp/six.py
python
Python 3.8.3 (default, May 17 2020, 18:15:42)
[GCC 10.1.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import six
>>> import wxwidgets
No problems in python, so it looks to be a path problem but six.py is clearly in /usr/local/grass78/gui/wxpython/mapdisp
Thanks in advance for any help, Dave Roberts
Hi Dave,
On Fri, Aug 7, 2020 at 12:34 AM Dave Roberts <droberts@montana.edu> wrote:
Friends,
version is broken).
(if you have separately any related error message(s), perhaps we can
reinstate it somehow?)
d.rast relief
File
line 6, in <module>
<module>
import six
Note, here it searches for the system "six".
I wonder if you have several python versions installed.
What do you get with this command, run in a GRASS GIS session?
echo $GRASS_PYTHON
python
Is that "natively" installed or through conda or the like?
>>> import six
>>> import wxwidgets
Did you run above in a GRASS GIS session?
Best,
