I need to obtain this format from shapefile, how do I?
ESRI ASCII Grid Format
(Copied from the ArcWorkstation 8.3 Help File)
The ASCII file must consist of header information containing a set of keywords, followed by cell values in row-major order. The file format is
<NCOLS xxx> <NROWS xxx> <XLLCENTER xxx | XLLCORNER xxx> <YLLCENTER xxx | YLLCORNER xxx> <CELLSIZE xxx> {NODATA_VALUE xxx} row 1 row 2 ... row n
where
xxx
is a number, and the keywordnodata_value
is optional and defaults to -9999. Row 1 of the data is at the top of the grid, row 2 is just under row 1 and so on. For example:ncols 386 nrows 286 xllcorner -128.66338 yllcorner 13.7502065 cellsize 0.2 NODATA_value -9999 -9999 -9999 -123 -123 -123 -9999 -9999 -9999 -9999 -9999 ... -9999 -9999 -123 -123 -123 -9999 -9999 -9999 -9999 -9999 ... -9999 -9999 -117 -117 -117 -119 -119 -119 -119 -119 -9999 ... ...
The
nodata_value
is the value in the ASCII file to be assigned to those cells whose true value is unknown. Cell values should be delimited by spaces. No carriage returns are necessary at the end of each row in the grid. The number of columns in the header is used to determine when a new row begins. The number of cell values must be equal to the number of rows times the number of columns.
I’m working
GRASS 6.4.2 (2012)
OSX 10.6.8
Many thanks,
Jose C. Guerrero
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
