[GRASS-user] (no subject)
Group,
I am running a grass-python script but when i replace a variable argument within the command the script does not work…
The following works…
grass.run_command(‘r.in.gdal’, input=‘/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif’, output=‘construction’)
But not this…
command=“‘r.in.gdal’, input='”+sys.argv[5]+“', output=‘construction’”
print 'r.in.gdal command argument… = %s\n ’ % command
grass.run_command(command)
print ‘r.in.gdal command argument… = %s\n ’ % command
r.in.gdal command argument… = ‘r.in.gdal’, input=’/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif’, output=‘construction’
The following also works…
command =“/home/alassane/Programs/gdal/demclass1”+" “+infile1+” “+infile2+” “+sys.argv[3]+” "+outfile
os.system(command)
Your help is appreciated.
Alassane
On Fri, Aug 12, 2016 at 1:05 PM, alassane toure <atourej@gmail.com> wrote:
Group,
within the command the script does not work....
The following works...
grass.run_command('r.in.gdal',
input='/home/alassane/Data/SanbornCD/tile/newconstr_mask.tif',
output='construction')
But not this...
command="'r.in.gdal', input='"+sys.argv[5]+"', output='construction'"
print 'r.in.gdal command argument... = %s\n ' % command
r.in.gdal command argument... = 'r.in.gdal',
The following also works...
command ="/home/alassane/Programs/gdal/demclass1"+" "+infile1+" "+infile2+"
"+sys.argv[3]+" "+outfile
os.system(command)
Perhaps this?
grass.run_command('r.in.gdal', input=sys.argv[5], output='construction')
Best,
Anna
Alassane
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Anna, it worked!
On Fri, Aug 12, 2016 at 11:31 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Group,
But not this…
os.system(command)
Perhaps this?
grass.run_command(‘r.in.gdal’, input=sys.argv[5], output=‘construction’)
Best,
Anna
Alassane
