[GRASS-user] not able to import and use pygrass
Hi I compiled Grass 7.0 (with OpenMP) on a CENTOS 7 OS.
everything works properly, but I’m not able to use PYGRASS
here is my first part of the codes if I add import pygrass I have the error:
import pygrass
ImportError: No module named pygrass
#!/usr/bin/env python
import os
import sys
import subprocess
import datetime, time
now = datetime.datetime.now()
StartTime = time.clock()
path to the GRASS GIS launch script
Linux
grass7bin_lin = ‘grass70’
DATA
define GRASS DATABASE # add your path to grassdata (GRASS GIS database) directory "~
gisdb = os.path.join(os.path.expanduser(“/DATA4/”), “grassdata”)
specify (existing) location and mapset
location = “EUROPE”
mapset = “LANDCOVER”
########### SOFTWARE
if sys.platform.startswith(‘linux’):
we assume that the GRASS GIS start script is available and in the PATH
query GRASS 7 itself for its GISBASE
grass7bin = grass7bin_lin
startcmd = [grass7bin, ‘–config’, ‘path’]
p = subprocess.Popen(startcmd, shell=False,
stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = p.communicate()
if p.returncode != 0:
print >>sys.stderr, “ERROR: Cannot find GRASS GIS 7 start script (%s)” % startcmd
sys.exit(-1)
gisbase = out.strip(‘\n\r’)
Set GISBASE environment variable
os.environ[‘GISBASE’] = gisbase
the following not needed with trunk
os.environ[‘PATH’] += os.pathsep + os.path.join(gisbase, ‘extrabin’)
define GRASS-Python environment
gpydir = os.path.join(gisbase, “etc”, “python”)
sys.path.append(gpydir)
########### DATA
Set GISDBASE environment variable
os.environ[‘GISDBASE’] = gisdb
from IPython.display import Image
from pprint import pprint
from subprocess import PIPE
import numpy as np
from grass import script
import subprocess
#looking(script, ‘command’)
import GRASS Python bindings (see also pygrass)
import grass.script as gscript
import grass.script.setup as gsetup
many thanks
Grazia
everything works properly, but I'm not able to use PYGRASS
     import pygrass
try
import grass.pygrass
pygrass is on the same level as script which you seem to be able to import successfully.
Moritz
On Mon, Jun 29, 2015 at 11:42 AM, Moritz Lennert <
error:
     import pygrass
try
successfully.
I fixed the documentation in:
https://trac.osgeo.org/grass/changeset/65526
When backported and updated online, it will be visible at:
http://grass.osgeo.org/grass70/manuals/libpython/pygrass_modules.html
The source code and its layout (which influences resulting package layout)
can be browsed here (lib/python directory becomes `grass` package):
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/
Reviews of documentation are welcome, patches accepted.
Vaclav
error:
     import pygrass
try
successfully.
For the record: the backport has been done and the pages linked here
are up to date.
