Hi!!
1.)I have downloaded grass-6-2.3. and then i add r.example into raster dir. make neccasy change inn the make file .
2)when i run make in raster/ dir …error comes permanent mapset:permission denied
as suggested by jachym i tried to download the source …but it require subversion…so i went for grass-6.2.3…am i wrong here??
- I configure ,make,make install the grass-6.2.3/ dir
- run grass62
please tell me how could i run my own sample file …
after i run grass how it’s effect could be seen …
r.example is taken from
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
Thanks & Regards
Kunal Malik
09871147561
Kunal Malik wrote:
Hi!!
dir.
2)when i run make in raster/ dir ..error comes permanent
mapset:permission
denied
as suggested by jachym i tried to download the source ..but it require
subversion...so i went for grass-6.2.3..am i wrong here??
3) I configure ,make,make install the grass-6.2.3/ dir
4) run grass62
please tell me how could i run my own sample file ..
after i run grass how it's effect could be seen ...
Thanks & Regards
Kunal Malik
09871147561
grass-user mailing list
grass-user@lists.osgeo.org
I think u have to create new mapset. u'll find an option to do that in the
GRASS startup screen. u can access data in PERMANENT from this mapset
View this message in context: http://www.nabble.com/Not-Able-to-Run-Sample-grass-data---tp15712474p15732132.html
