Greetings
I have a vector map with the following characteristics (v.info)
v.info test01_LU
| Layer: test01_LU |
| Mapset: Regional |
| Database: D:\data |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: monica |
| Organization: |
Source date: Tue Nov 23 11:19:55 2010 |
Type of Map: vector (level: 2) |
Number of points: 0 Number of areas: 76832 |
Number of lines: 0 Number of islands: 7949 |
Number of boundaries: 172475 Number of faces: 0 |
Number of centroids: 76816 Number of kernels: 0 |
Map is 3D: No |
Number of dblinks: 1 |
Projection: Transverse Mercator |
N: 276083.7674 S: -300404.804 |
E: 162129.0811 W: -119191.4075 |
Digitization threshold: 0 |
Comments: |
(Tue Nov 23 11:41:42 2010) Command finished (0 sec) |
When I try to display it in a Map Window my wxGUI freezes and it gets non responsive. What might be happen? DO you suggest to “wait”?
