Lets say I have a map with a range of -20, and 20. I am able to create a legend that only shows -10,10. But I want my map to only show values from -10,10. Is there a way to make the areas that are above 10, or below -10 show up as white or null values on the display map. I have been playing around with val. list in d.rast. But I have not had much sucess in creating maps that take out my max and min outliers. Any suggestions?
Aaron
you can use r.mapcalc or r.null
c
Aaron_______________________________________________
grassuser mailing list
grassuser@grass.itc.it
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
If the maps are integer-valued, use r.reclass to map the undesired
categories to null.
If the maps have floating-point values, use r.mapcalc instead.
While the r.mapcalc approach will work for integer values, it copies
the map data, while r.reclass only need to store the reclass rules.
See r.colors for display colours...
you should define your color rules...
Alternatively you can create/modify your color file (same name of your
raster map) under the colr folder of your mapset.
e.g.:
% -20 20
-20:255:255:255 -10:255:255:255
-10:255:0:0 10:0:255:0
10:255:255:255 20:255:255:255
these represent in withe cells with values lower -10 and upper +10, and
from red to green in between
lines mean:
(from -20 to -10 ramp between 255:255:255 and 255:255:255)-.>withe
(from -10 to 10 ramp between 255:0:0 and 0:255:0)->red to green
(from 10 to 20 ramp between 255:255:255 and 255:255:255) -.>withe
bye
Maxi
I assume yue use gui, do temporary display only values from -10 to 10 simply in "values to display" type: -10-10
that all
Jarek
